[GeoNode-users] Changing Theme for Geonode 2.10
Ran L.
kula009 at gmail.com
Wed May 8 10:29:02 PDT 2019
Hello Cliff,
I'm also working on the Geonode project and had similar issues to yours.
After struggling with the package installations and getting no success, I
decided to go with the docker. Surprisingly everything went well after
using docker!
Just follow the instructions on https://github.com/GeoNode/geonode-project.
Skip the part " Create a custom project" entirely because it has nothing
to do with docker. Start directly from "Start your server" and work on.
If you follow the instructions precisely, you'll be able to customize the
Geonode by only modifying files in the "my_geonode" folder without touching
the core. If you want to see changes being applied immediately, make sure
you run docker-compose in dev mode:
docker-compose -f docker-compose.development.yml -f
docker-compose.development.override.yml up
Let me know if you need more assistance!
Best,
Ran
On Wed, May 8, 2019 at 10:05 AM Cliff Patterson <cpatterson at psdrcs.com>
wrote:
> Hi Angelos,
> Thanks for your help, but I can't get Geonode-project up and running. I
> just get error after error. I am using the instructions on github
> For example, when running pip install -r requirements.txt --upgrade:
> ERROR: Complete output from command python setup.py egg_info:
> ERROR: Failed `CDLL(libgeos_c.so.1)`
> Failed `CDLL(libgeos_c.so)`
> Traceback (most recent call last):
> File "<string>", line 1, in <module>
> File "/tmp/pip-install-UUny1E/Shapely/setup.py", line 38, in <module>
> from shapely._buildcfg import geos_version_string, geos_version, \
> File "shapely/_buildcfg.py", line 167, in <module>
> fallbacks=['libgeos_c.so.1', 'libgeos_c.so'])
> File "shapely/_buildcfg.py", line 161, in load_dll
> libname, fallbacks or []))
> OSError: Could not find library geos_c or load any of its variants
> ERROR: Command "python setup.py egg_info" failed with error code 1 in
> Error when running: pip install pygdal==$PYGDAL_VERSION
> ERROR: Invalid requirement: '.8'
> At this point, nothing works... So let's start over.
> What is the starting point to install a version of geonode that can be
> customized on a fresh installation of Ubuntu 18.04?
> Big thanks!
> Cliff
> On Wed, May 8, 2019 at 5:25 AM Angelos Tzotsos <gcpp.kalxas at gmail.com>
> wrote:
>> Hi,
>> Please keep posting to GeoNode mailing list so that others can follow
>> and help.
>> Since you used the pre-release ppa, only geonode is installed, without a
>> geonode-project setup for customization.
>> Please have a look here for details:
>> Best,
>> Angelos
>> On 5/8/19 4:05 AM, Cliff Patterson wrote:
>> > I was not sure which directory to edit in order to customize the look of
>> > geonode (e.g. change logo, menu colour). Ultimately I would like to
>> create
>> > a theme that I can replicate on several servers, but not sure how to
>> > proceed. I installed on Ubuntu 18.04 using the geonode pre-release PPA.
>> > With the default settings, there are two "static" directories when I
>> search
>> > the server for "geonode", one at:
>> > /usr/local/lib/python2.7/dist-packages/geonode/static/geonode/
>> > And another in the web root:
>> > /var/www/geonode/static/geonode
>> > I'm not that familiar with Django so really not sure which directory to
>> > edit. The docs say "Your GeoNode project has a directory already set up
>> for
>> > storing your own images at <my_geonode>/static/img
>> > ". Where is <my_geonode>?
>> > Cheers,
>> > Cliff
>> > On Tue., May 7, 2019, 5:28 p.m. Angelos Tzotsos, <gcpp.kalxas at gmail.com
>> > wrote:
>> >> Hi Cliff,
>> >> The documentation seems right. Are you working with a geonode-project
>> or
>> >> are you trying to customize the geonode itself?
>> >> Cheers,
>> >> Angelos
>> >> On 5/7/19 11:48 PM, Cliff Patterson wrote:
>> >> Are there docs on how to change the geonode theme (e.g. brand logo)
>> when
>> >> installing 2.10 from the testing PPA? The instructions here do not
>> seem to
>> >> be valid:
>> http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/theme_admin.html#theme-admin
>> >> Thanks!
>> >> Cliff
>> >> _______________________________________________
>> >> geonode-users mailing listgeonode-users at lists.osgeo.orghttps://
>> lists.osgeo.org/mailman/listinfo/geonode-users
>> >> Angelos Tzotsos, PhD
>> >> Charter Member
>> >> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos
>> Charter Member
> Cliff Patterson Ph.D.
> *PSD* | Senior GIS Consultant
> P: 519-690-2565 ext. 2565
> www.psdrcs.com
> London | 148 Fullarton St. 9th Floor
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190508/f694cf15/attachment-0001.html>
More information about the geonode-users
