[GeoNode-users] Changing Theme for Geonode 2.10
Cliff Patterson
cpatterson at psdrcs.com
Wed May 8 10:31:25 PDT 2019
Hi Ran!
Thanks so much for the advice. I will give this a go now!
Cliff
On Wed, May 8, 2019 at 1:29 PM Ran L. <kula009 at gmail.com> wrote:
> Hello Cliff,
> I'm also working on the Geonode project and had similar issues to yours.
> After struggling with the package installations and getting no success, I
> decided to go with the docker. Surprisingly everything went well after
> using docker!
> Just follow the instructions on https://github.com/GeoNode/geonode-project.
> Skip the part " Create a custom project" entirely because it has nothing
> to do with docker. Start directly from "Start your server" and work on.
> If you follow the instructions precisely, you'll be able to customize the
> Geonode by only modifying files in the "my_geonode" folder without touching
> the core. If you want to see changes being applied immediately, make sure
> you run docker-compose in dev mode:
> docker-compose -f docker-compose.development.yml -f docker-compose.development.override.yml up
> Let me know if you need more assistance!
> Best,
> Ran
> On Wed, May 8, 2019 at 10:05 AM Cliff Patterson <cpatterson at psdrcs.com>
> wrote:
>> Hi Angelos,
>> Thanks for your help, but I can't get Geonode-project up and running. I
>> just get error after error. I am using the instructions on github
>> For example, when running pip install -r requirements.txt --upgrade:
>> ERROR: Complete output from command python setup.py egg_info:
>> ERROR: Failed `CDLL(libgeos_c.so.1)`
>> Failed `CDLL(libgeos_c.so)`
>> Traceback (most recent call last):
>> File "<string>", line 1, in <module>
>> File "/tmp/pip-install-UUny1E/Shapely/setup.py", line 38, in
>> <module>
>> from shapely._buildcfg import geos_version_string, geos_version, \
>> File "shapely/_buildcfg.py", line 167, in <module>
>> fallbacks=['libgeos_c.so.1', 'libgeos_c.so'])
>> File "shapely/_buildcfg.py", line 161, in load_dll
>> libname, fallbacks or []))
>> OSError: Could not find library geos_c or load any of its variants
>> ERROR: Command "python setup.py egg_info" failed with error code 1 in
>> Error when running: pip install pygdal==$PYGDAL_VERSION
>> ERROR: Invalid requirement: '.8'
>> At this point, nothing works... So let's start over.
>> What is the starting point to install a version of geonode that can be
>> customized on a fresh installation of Ubuntu 18.04?
>> Big thanks!
>> Cliff
>> On Wed, May 8, 2019 at 5:25 AM Angelos Tzotsos <gcpp.kalxas at gmail.com>
>> wrote:
>>> Hi,
>>> Please keep posting to GeoNode mailing list so that others can follow
>>> and help.
>>> Since you used the pre-release ppa, only geonode is installed, without a
>>> geonode-project setup for customization.
>>> Please have a look here for details:
>>> Best,
>>> Angelos
>>> On 5/8/19 4:05 AM, Cliff Patterson wrote:
>>> > I was not sure which directory to edit in order to customize the look
>>> of
>>> > geonode (e.g. change logo, menu colour). Ultimately I would like to
>>> create
>>> > a theme that I can replicate on several servers, but not sure how to
>>> > proceed. I installed on Ubuntu 18.04 using the geonode pre-release PPA.
>>> > With the default settings, there are two "static" directories when I
>>> search
>>> > the server for "geonode", one at:
>>> > /usr/local/lib/python2.7/dist-packages/geonode/static/geonode/
>>> > And another in the web root:
>>> > /var/www/geonode/static/geonode
>>> > I'm not that familiar with Django so really not sure which directory to
>>> > edit. The docs say "Your GeoNode project has a directory already set
>>> up for
>>> > storing your own images at <my_geonode>/static/img
>>> > ". Where is <my_geonode>?
>>> > Cheers,
>>> > Cliff
>>> > On Tue., May 7, 2019, 5:28 p.m. Angelos Tzotsos, <
>>> > wrote:
>>> >> Hi Cliff,
>>> >> The documentation seems right. Are you working with a geonode-project
>>> or
>>> >> are you trying to customize the geonode itself?
>>> >> Cheers,
>>> >> Angelos
>>> >> On 5/7/19 11:48 PM, Cliff Patterson wrote:
>>> >> Are there docs on how to change the geonode theme (e.g. brand logo)
>>> when
>>> >> installing 2.10 from the testing PPA? The instructions here do not
>>> seem to
>>> >> be valid:
>>> http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/theme_admin.html#theme-admin
>>> >> Thanks!
>>> >> Cliff
>>> >> _______________________________________________
>>> >> geonode-users mailing listgeonode-users at lists.osgeo.orghttps://
>>> lists.osgeo.org/mailman/listinfo/geonode-users
>>> >> Angelos Tzotsos, PhD
>>> >> Charter Member
>>> >> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos
>>> Charter Member
>> Cliff Patterson Ph.D.
>> *PSD* | Senior GIS Consultant
>> P: 519-690-2565 ext. 2565
>> www.psdrcs.com
>> London | 148 Fullarton St. 9th Floor
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
www.psdrcs.com
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190508/be0da6ae/attachment.html>
More information about the geonode-users
