[GeoNode-users] Changing Theme for Geonode 2.10
Cliff Patterson
cpatterson at psdrcs.com
Wed May 8 12:02:56 PDT 2019
Everything worked until the last step ( docker-compose up)
The final error reads:
ERROR: An HTTP request took too long to complete. Retry with --verbose to
obtain debug information.
If you encounter this issue regularly because of slow network conditions,
consider setting COMPOSE_HTTP_TIMEOUT to a higher value (current value: 60).
Cheers,
Cliff
On Wed, May 8, 2019 at 1:32 PM Ran L. <kula009 at gmail.com> wrote:
> You're welcome! Hope it helps!
> On Wed, May 8, 2019 at 10:31 AM Cliff Patterson <cpatterson at psdrcs.com>
> wrote:
>> Hi Ran!
>> Thanks so much for the advice. I will give this a go now!
>> Cliff
>> On Wed, May 8, 2019 at 1:29 PM Ran L. <kula009 at gmail.com> wrote:
>>> Hello Cliff,
>>> I'm also working on the Geonode project and had similar issues to yours.
>>> After struggling with the package installations and getting no success, I
>>> decided to go with the docker. Surprisingly everything went well after
>>> using docker!
>>> Just follow the instructions on
>>> https://github.com/GeoNode/geonode-project. Skip the part " Create a
>>> custom project" entirely because it has nothing to do with docker. Start
>>> directly from "Start your server" and work on.
>>> If you follow the instructions precisely, you'll be able to customize
>>> the Geonode by only modifying files in the "my_geonode" folder without
>>> touching the core. If you want to see changes being applied immediately,
>>> make sure you run docker-compose in dev mode:
>>> docker-compose -f docker-compose.development.yml -f docker-compose.development.override.yml up
>>> Let me know if you need more assistance!
>>> Best,
>>> Ran
>>> On Wed, May 8, 2019 at 10:05 AM Cliff Patterson <cpatterson at psdrcs.com>
>>> wrote:
>>>> Hi Angelos,
>>>> Thanks for your help, but I can't get Geonode-project up and running. I
>>>> just get error after error. I am using the instructions on github
>>>> For example, when running pip install -r requirements.txt --upgrade:
>>>> ERROR: Complete output from command python setup.py egg_info:
>>>> ERROR: Failed `CDLL(libgeos_c.so.1)`
>>>> Failed `CDLL(libgeos_c.so)`
>>>> Traceback (most recent call last):
>>>> File "<string>", line 1, in <module>
>>>> File "/tmp/pip-install-UUny1E/Shapely/setup.py", line 38, in
>>>> <module>
>>>> from shapely._buildcfg import geos_version_string,
>>>> geos_version, \
>>>> File "shapely/_buildcfg.py", line 167, in <module>
>>>> fallbacks=['libgeos_c.so.1', 'libgeos_c.so'])
>>>> File "shapely/_buildcfg.py", line 161, in load_dll
>>>> libname, fallbacks or []))
>>>> OSError: Could not find library geos_c or load any of its variants
>>>> ERROR: Command "python setup.py egg_info" failed with error code 1 in
>>>> Error when running: pip install pygdal==$PYGDAL_VERSION
>>>> ERROR: Invalid requirement: '.8'
>>>> At this point, nothing works... So let's start over.
>>>> What is the starting point to install a version of geonode that can be
>>>> customized on a fresh installation of Ubuntu 18.04?
>>>> Big thanks!
>>>> Cliff
>>>> On Wed, May 8, 2019 at 5:25 AM Angelos Tzotsos <gcpp.kalxas at gmail.com>
>>>> wrote:
>>>>> Hi,
>>>>> Please keep posting to GeoNode mailing list so that others can follow
>>>>> and help.
>>>>> Since you used the pre-release ppa, only geonode is installed, without
>>>>> a
>>>>> geonode-project setup for customization.
>>>>> Please have a look here for details:
>>>>> Best,
>>>>> Angelos
>>>>> On 5/8/19 4:05 AM, Cliff Patterson wrote:
>>>>> > I was not sure which directory to edit in order to customize the
>>>>> look of
>>>>> > geonode (e.g. change logo, menu colour). Ultimately I would like to
>>>>> create
>>>>> > a theme that I can replicate on several servers, but not sure how to
>>>>> > proceed. I installed on Ubuntu 18.04 using the geonode pre-release
>>>>> PPA.
>>>>> > With the default settings, there are two "static" directories when I
>>>>> search
>>>>> > the server for "geonode", one at:
>>>>> > /usr/local/lib/python2.7/dist-packages/geonode/static/geonode/
>>>>> > And another in the web root:
>>>>> > /var/www/geonode/static/geonode
>>>>> > I'm not that familiar with Django so really not sure which directory
>>>>> to
>>>>> > edit. The docs say "Your GeoNode project has a directory already set
>>>>> up for
>>>>> > storing your own images at <my_geonode>/static/img
>>>>> > ". Where is <my_geonode>?
>>>>> > Cheers,
>>>>> > Cliff
>>>>> > On Tue., May 7, 2019, 5:28 p.m. Angelos Tzotsos, <
>>>>> > wrote:
>>>>> >> Hi Cliff,
>>>>> >> The documentation seems right. Are you working with a
>>>>> geonode-project or
>>>>> >> are you trying to customize the geonode itself?
>>>>> >> Cheers,
>>>>> >> Angelos
>>>>> >> On 5/7/19 11:48 PM, Cliff Patterson wrote:
>>>>> >> Are there docs on how to change the geonode theme (e.g. brand logo)
>>>>> when
>>>>> >> installing 2.10 from the testing PPA? The instructions here do not
>>>>> seem to
>>>>> >> be valid:
>>>>> http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/theme_admin.html#theme-admin
>>>>> >> Thanks!
>>>>> >> Cliff
>>>>> >> _______________________________________________
>>>>> >> geonode-users mailing listgeonode-users at lists.osgeo.orghttps://
>>>>> lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> >> Angelos Tzotsos, PhD
>>>>> >> Charter Member
>>>>> >> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos
>>>>> Charter Member
>>>> Cliff Patterson Ph.D.
>>>> *PSD* | Senior GIS Consultant
>>>> P: 519-690-2565 ext. 2565
>>>> www.psdrcs.com
>>>> London | 148 Fullarton St. 9th Floor
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> www.psdrcs.com
www.psdrcs.com
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190508/0ef5d24f/attachment.html>
More information about the geonode-users
