[GeoNode-users] Changing Theme for Geonode 2.10
MDG DEE
kula009 at gmail.com
Wed May 8 12:27:53 PDT 2019
Never had this issue before. Since it is a time out, can you check your network condition?
Ran
> On May 8, 2019, at 12:02 PM, Cliff Patterson <cpatterson at psdrcs.com> wrote:
> Everything worked until the last step ( docker-compose up)
> The final error reads:
> ERROR: An HTTP request took too long to complete. Retry with --verbose to obtain debug information.
> If you encounter this issue regularly because of slow network conditions, consider setting COMPOSE_HTTP_TIMEOUT to a higher value (current value: 60).
> Cheers,
> Cliff
>> On Wed, May 8, 2019 at 1:32 PM Ran L. <kula009 at gmail.com> wrote:
>> You're welcome! Hope it helps!
>>> On Wed, May 8, 2019 at 10:31 AM Cliff Patterson <cpatterson at psdrcs.com> wrote:
>>> Hi Ran!
>>> Thanks so much for the advice. I will give this a go now!
>>> Cliff
>>>> On Wed, May 8, 2019 at 1:29 PM Ran L. <kula009 at gmail.com> wrote:
>>>> Hello Cliff,
>>>> I'm also working on the Geonode project and had similar issues to yours. After struggling with the package installations and getting no success, I decided to go with the docker. Surprisingly everything went well after using docker!
>>>> Just follow the instructions on https://github.com/GeoNode/geonode-project. Skip the part " Create a custom project" entirely because it has nothing to do with docker. Start directly from "Start your server" and work on.
>>>> If you follow the instructions precisely, you'll be able to customize the Geonode by only modifying files in the "my_geonode" folder without touching the core. If you want to see changes being applied immediately, make sure you run docker-compose in dev mode:
>>>> docker-compose -f docker-compose.development.yml -f docker-compose.development.override.yml up
>>>> Let me know if you need more assistance!
>>>> Best,
>>>> Ran
>>>>> On Wed, May 8, 2019 at 10:05 AM Cliff Patterson <cpatterson at psdrcs.com> wrote:
>>>>> Hi Angelos,
>>>>> Thanks for your help, but I can't get Geonode-project up and running. I just get error after error. I am using the instructions on github https://github.com/GeoNode/geonode-project
>>>>> For example, when running pip install -r requirements.txt --upgrade:
>>>>> ERROR: Complete output from command python setup.py egg_info:
>>>>> ERROR: Failed `CDLL(libgeos_c.so.1)`
>>>>> Failed `CDLL(libgeos_c.so)`
>>>>> Traceback (most recent call last):
>>>>> File "<string>", line 1, in <module>
>>>>> File "/tmp/pip-install-UUny1E/Shapely/setup.py", line 38, in <module>
>>>>> from shapely._buildcfg import geos_version_string, geos_version, \
>>>>> File "shapely/_buildcfg.py", line 167, in <module>
>>>>> fallbacks=['libgeos_c.so.1', 'libgeos_c.so'])
>>>>> File "shapely/_buildcfg.py", line 161, in load_dll
>>>>> libname, fallbacks or []))
>>>>> OSError: Could not find library geos_c or load any of its variants ['libgeos_c.so.1', 'libgeos_c.so']
>>>>> ERROR: Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-UUny1E/Shapely/
>>>>> Error when running: pip install pygdal==$PYGDAL_VERSION
>>>>> ERROR: Invalid requirement: '.8'
>>>>> At this point, nothing works... So let's start over.
>>>>> What is the starting point to install a version of geonode that can be customized on a fresh installation of Ubuntu 18.04?
>>>>> Big thanks!
>>>>> Cliff
>>>>>> On Wed, May 8, 2019 at 5:25 AM Angelos Tzotsos <gcpp.kalxas at gmail.com> wrote:
>>>>>> Hi,
>>>>>> Please keep posting to GeoNode mailing list so that others can follow
>>>>>> and help.
>>>>>> Since you used the pre-release ppa, only geonode is installed, without a
>>>>>> geonode-project setup for customization.
>>>>>> Please have a look here for details:
>>>>>> Best,
>>>>>> Angelos
>>>>>> On 5/8/19 4:05 AM, Cliff Patterson wrote:
>>>>>> > I was not sure which directory to edit in order to customize the look of
>>>>>> > geonode (e.g. change logo, menu colour). Ultimately I would like to create
>>>>>> > a theme that I can replicate on several servers, but not sure how to
>>>>>> > proceed. I installed on Ubuntu 18.04 using the geonode pre-release PPA.
>>>>>> > With the default settings, there are two "static" directories when I search
>>>>>> > the server for "geonode", one at:
>>>>>> > /usr/local/lib/python2.7/dist-packages/geonode/static/geonode/
>>>>>> > And another in the web root:
>>>>>> > /var/www/geonode/static/geonode
>>>>>> > I'm not that familiar with Django so really not sure which directory to
>>>>>> > edit. The docs say "Your GeoNode project has a directory already set up for
>>>>>> > storing your own images at <my_geonode>/static/img
>>>>>> > ". Where is <my_geonode>?
>>>>>> > Cheers,
>>>>>> > Cliff
>>>>>> > On Tue., May 7, 2019, 5:28 p.m. Angelos Tzotsos, <gcpp.kalxas at gmail.com>
>>>>>> > wrote:
>>>>>> >> Hi Cliff,
>>>>>> >> The documentation seems right. Are you working with a geonode-project or
>>>>>> >> are you trying to customize the geonode itself?
>>>>>> >> Cheers,
>>>>>> >> Angelos
>>>>>> >> On 5/7/19 11:48 PM, Cliff Patterson wrote:
>>>>>> >> Are there docs on how to change the geonode theme (e.g. brand logo) when
>>>>>> >> installing 2.10 from the testing PPA? The instructions here do not seem to
>>>>>> >> be valid:
>>>>>> >> http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/theme_admin.html#theme-admin
>>>>>> >> Thanks!
>>>>>> >> Cliff
>>>>>> >> _______________________________________________
>>>>>> >> geonode-users mailing listgeonode-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> >> Angelos Tzotsos, PhD
>>>>>> >> Charter Member
>>>>>> >> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos
>>>>>> Charter Member
>>>>> Cliff Patterson Ph.D.
>>>>> PSD | Senior GIS Consultant
>>>>> P: 519-690-2565 ext. 2565
>>>>> www.psdrcs.com
>>>>> London | 148 Fullarton St. 9th Floor
>>> www.psdrcs.com
> www.psdrcs.com
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190508/da2d1cd4/attachment-0001.html>
More information about the geonode-users
