[GeoNode-users] Geonode - uploading works but imports empty layers
Muhammad Nabi Ahmad
mnabiahmad at gmail.com
Wed May 15 02:53:53 PDT 2019
Dear Toni
Thanks for the quick response.
Please see the attached shape file.
Best regards
Muhammad
From: Toni Schönbuchner <toni.schoenbuchner at csgis.de>
Date: Wednesday, May 15, 2019 at 12:50 PM
To: Muhammad Nabi Ahmad <mnabiahmad at gmail.com>
Cc: <mn.sabatino at gmail.com>, geonode-users <geonode-users at lists.osgeo.org>
Subject: Re: [GeoNode-users] Geonode - uploading works but imports empty layers
Dear Muhammad,
would it work for you to priovide me the file you´ve tested with?
With best regards,
Toni
Am 15.05.2019 um 11:37 schrieb Muhammad Nabi Ahmad <mnabiahmad at gmail.com>:
Dear Toni, Manuela and All
I am having the same issue. I installed GeoNode 2.8 (using apt-get) on Ubuntu 16.04. The debug option is already true but there is no error while uploading. Once the shape file is uploaded I am also allowed to add metadata as well. Finally, when I view the uploaded layer, I see incorrect bbox (database and GeoServer has incorrect bbox) but even if I pan/zoom to my specific location I cannot see any features. I looked at the database and found the spatial table for layer is empty (but has all the attributes, means table structure was created correctly). I have tried uploading 2 different shape file but both has the same result.
Note: Raster layers and Document works fine, its only shape file that is having an issue.
Thanks Best regards
Muhammad Ahmad
From: geonode-users <geonode-users-bounces at lists.osgeo.org> on behalf of Toni Schönbuchner <toni.schoenbuchner at csgis.de>
Date: Tuesday, March 20, 2018 at 10:53 AM
To: <mn.sabatino at gmail.com>
Cc: geonode-users <geonode-users at lists.osgeo.org>
Dear Manuela,
how did you install geonode and under which OS?
Further do you see anything useful in geoserver.log with
verbose logging set?
You can also switch on Django DEBUG in local_settings
DEBUG = TEMPLATE_DEBUG = True
to get more information.
Best Regards,
Toni
CSGIS
Kolonnadenstraße 1
04109 Leipzig
Mobil +49/ (0) 176 6680 3198
Tel +49/ (0) 341 24 04 738
Fax +49/ (0) 341 24 04 73
Web http://csgis.de
Hinweis gemäß § 33 BDSG
Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
Am 19.03.2018 um 20:00 schrieb geonode-users-request at lists.osgeo.org:
Message: 1
Date: Mon, 19 Mar 2018 12:04:26 +0000
To: geonode-users at lists.osgeo.org
Subject: [GeoNode-users] Geonode - uploading works but imports empty
layers
Message-ID:
<CAG4qXndqFp6-DOHGWsJv-gXRtkADi743Hb7NRAB5NKdw7SQxrw at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
This is Manuela here, I am newbie in Geonode. I just started working on a
Geonode project and I am quite new in the field. I worked as a GIS Analysts
for almost 5 years and self-taught web development, Python, Django, JS,
CSS, HTML etc..
At the moment, we built a demo that is not successfully working
unfortunately, since I know I do have a lot to learn how to make it work
properly I was wondering if you could also help me to fix some issues below
listed:
- When I click on the geofence test connection in the geoserver it shows an
error:
ERROR [auth.GeoFenceAuthenticationProvider] - Error in authenticating with
GeoFence
com.google.common.util.concurrent.UncheckedExecutionException:
org.springframework.transaction.CannotCreateTransactionException: Could not
open JPA EntityManager for transaction; nested exception is
javax.persistence.PersistenceException:
- When I try to upload a shp file from the geonode website it works but the
layer is empty, with no features in it.
I can see the layer stored in the geoserver and the postgres database but
there are no records in it.
I would really appreciate if you could help in debugging these issues.
I am looking forward to hearing from you,
*Manuela Sabatino*
*T* +44 7598 060 934
*E* mn.sabatino at gmail.com
_______________________________________________ geonode-users mailing list geonode-users at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190515/34ace043/attachment-0001.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190515/34ace043/attachment-0001.zip>
More information about the geonode-users
