[GeoNode-users] Proxy error with geoserver link in my profile
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed May 29 00:29:24 PDT 2019
Hello Maxime,
define either an environment variable or set explicitly on your settings
the following variable
GEOSERVER_WEB_UI_LOCATION=http://<full_address_of_geoserver>/
Il giorno mer 29 mag 2019 alle ore 03:32 Maxime Audet-Roberge <
maximeaudetr at hotmail.com> ha scritto:
> Hello GeoNode Users,
> I installed GeoNode 2.10 rc5 on a Ubuntu 18.04 VM following the guide
> written by GeoSolutions (
> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit).
> I also installed GeoServer 2.15.1. Almost everything is working fine so
> far, I have access to geoserver and the authentication works! However, I
> have some issues. Here is one: the link to geoserver in my profile is not
> working and I have a proxy error.
> When I click on the top left menu (I am logged as admin), the GeoServer
> link is localhost/geoserver. This link is workong fine when I click on it.
> However, if I open my profile (localhost/people/admin/), the link to
> geoserver will be localhost/proxy/?url=http://localhost/geoserver. When I
> click on this link, I have the following message in my browser : “The
> proxy service requires a URL-encoded URL as a parameter.” and the address
> is “localhost/proxy/web”.
> Do you have any idea how I can avoid this error?
> Thanks a lot!
> Maxime
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190529/a3e4450c/attachment.html>
More information about the geonode-users mailing list
