[GeoNode-users] Query builder on geonode
Silvia Salsone salsone at planetek.it
Thu Nov 14 02:35:20 PST 2019
Good morning,
I was asked if the user could filter on the layer in viewing mode, without the saving option.
Do you have any suggestion on this?
Thank you so much.
Cheers,
Silvia
From: Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it]
Sent: mercoledì 13 novembre 2019 17:34
To: Silvia Salsone <salsone at planetek.it>
Cc: geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] Query builder on geonode
Hello Silvia,
if you have edit permissions on a layer, you can access the query builder by clicking over it from the TOC.
A small icon will appear on the top as soon as you highlight the layer.
Cheers,
Alessio.
Il giorno mer 13 nov 2019 alle ore 17:30 Silvia Salsone <salsone at planetek.it<mailto:salsone at planetek.it>> ha scritto:
Dear all,
We need a system able to perform on line queries on maps. We are already using GeoNode and I found a suitable query builder in MapStore. In particular, on the news of the MapStore release on February 2018 (https://www.geo-solutions.it/blog/mapstore-release-charts/),  I can read about a restyling of the query builder and the integration of MapStore with GeoNode is set as future work.
How can I check if my version of GeoNode (2.10) has got the query builder? How to use/access it?
Thank you very much.
Best regards,
Silvia
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191114/2cd93f55/attachment.html>
More information about the geonode-users mailing list
