[GeoNode-users] After data restore maps are not centered.
Chiara Sammarco chiara.sammarco at geodatalab.it
Tue Nov 26 07:44:07 PST 2019
Hi all,
I'm working with SPCgeonode 2.10 on Ubuntu 18.04.
I've restored data from an old installation of Geonode and I managed to see
layers, maps and documents in geonode app.
The only thing is that the maps are not well centered in mapstore2.
I've checked the database and see, that for all the maps the projection
field is: EPSG:900913
I've checked in this way:
> select projection, center_x, center_y, zoom from maps_map;
In settings.py I've set:
> DEFAULT_MAP_CRS = "EPSG:900913"
and also DEFAULT_MAP_CENTER, DEFAULT_MAP_ZOOM to some proper values, but it
does not change the behaviour.
Do you have any suggestions?
Thanks in advance for your help,
Best Regards
Chiara
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191126/7cfb6acd/attachment.html>
More information about the geonode-users mailing list
