[GeoNode-users] GeoNode and ETL
Simone Giannecchini
simone.giannecchini at geo-solutions.it
Tue Oct 1 10:42:18 PDT 2019
Hi Magnus,
please, read below...
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 333 8128928
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
On Tue, Oct 1, 2019 at 1:14 PM Magnus Nilsson <johnrobot at gmail.com> wrote:
> Hi
> I have a few questions about GeoNode:
> - Is it possible to expose the metadata using DCAT-AP? It seems to be the
> standard used by https://oppnadata.se/, which is where I want our geodata
> to be displayed.
I don't think this is supported out of the box; I believe, it would require
some development both in terms of supporting the additional elements in the
model as well as in terms of outputting them.
> - We use FME, https://www.safe.com/, a lot for geodata ETL tasks. Can I
> register data sets in GeoNode without uploading any data via the web
> interface and instead point it to the correct PostGIS table? I would like
> to use FME to write data to PostGIS and then configure GeoNode to discover
> the new PostGIS table and display its content to our users. Having to
> convert to SHP and upload that seems like a step backwards.
One way to achieve that is to register them in GeoServer and then call the
updateLayers command; in any case, I believe we would need to make sure we
do not loose any of the standard GeoNode functionalities.
> Regards,
> Magnus
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191001/afdf8055/attachment.html>
More information about the geonode-users
