[GeoNode-users] GeoNode and ETL
Magnus Nilsson johnrobot at gmail.com
Wed Oct 2 02:55:25 PDT 2019
Hi Simone
Thanks for your reply. In our case, I think it would be a priority to have
support for a workflow where we can use FME (or perhaps a QGIS processing
model writing to PostGIS, somewhere down the road) to add data to the
database used by GeoNode. I have not really used GeoNode, beyond the demo
at http://master.demo.geonode.org/, so I don´t know how to call the
updateLayers command, but I´m sure I can find some documentation on that.
Should that command also be used when overwriting an existing table, when
updating the data (again, using FME)? Perhaps GeoNode could automatically
detect new/updated tables in the database and ask the admin to configure
them in GeoNode?
Magnus
On Tue, Oct 1, 2019 at 7:42 PM Simone Giannecchini <
simone.giannecchini at geo-solutions.it> wrote:
> Hi Magnus,
> please, read below...
> Regards,
> Simone Giannecchini
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services for more information.
> Ing. Simone Giannecchini
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  333 8128928
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> On Tue, Oct 1, 2019 at 1:14 PM Magnus Nilsson <johnrobot at gmail.com> wrote:
>> Hi
>> I have a few questions about GeoNode:
>> - Is it possible to expose the metadata using DCAT-AP? It seems to be the
>> standard used by https://oppnadata.se/, which is where I want our
>> geodata to be displayed.
> I don't think this is supported out of the box; I believe, it would
> require some development both in terms of supporting the additional
> elements in the model as well as in terms of outputting them.
>> - We use FME, https://www.safe.com/, a lot for geodata ETL tasks. Can I
>> register data sets in GeoNode without uploading any data via the web
>> interface and instead point it to the correct PostGIS table? I would like
>> to use FME to write data to PostGIS and then configure GeoNode to discover
>> the new PostGIS table and display its content to our users. Having to
>> convert to SHP and upload that seems like a step backwards.
>  One way to achieve that is to register them in GeoServer and then call
> the updateLayers command; in any case, I believe we would need to make sure
> we do not loose any of the standard GeoNode functionalities.
>> Regards,
>> Magnus
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191002/27896e8a/attachment.html>
More information about the geonode-users mailing list
