[GeoNode-users] Set layer visibility to registered users
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Oct 21 05:52:31 PDT 2019
Unfortunately not, the Pull Request has been merged 5 days ago
https://github.com/GeoNode/geonode/pull/5045
Il giorno lun 21 ott 2019 alle ore 13:20 EFTAS Oliver Buck <
oliver.buck at eftas.com> ha scritto:
> Thanks Alessio,
> we checked out the latest Genode Version (2.10.x) as of 08.10.2019.
> Did this feature come in later?
> Thanks
> Oliver
> *Von:* Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it]
> *Gesendet:* Montag, 21. Oktober 2019 12:39
> *An:* EFTAS Oliver Buck
> *Cc:* geonode-users at lists.osgeo.org
> *Betreff:* Re: [GeoNode-users] Set layer visibility to registered users
> Hi,
> by updating to the latest version of GeoNode, you will have a new group
> available, automatically created at initialization time, called "Registered
> Users".
> You will be able to select this group in order to set the objects
> permissions.
> Il giorno lun 21 ott 2019 alle ore 12:31 EFTAS Oliver Buck <
> Dear all,
> I am currently setting up a Geonode and would like to set the visibility
> of several layers according to the user being registered or not. This means
> some layers shall be visible only to registered users, while some shall be
> visible for all users.
> What is the best way to set this up?
> I found this setting
> http://docs.geonode.org/en/2.10.x/basic/settings/index.html#auto-assign-registered-members-to-registered-members-group-name
> , but are not sure, if this is what I need? Do I then have to create a
> “Registered Users” group via the Django Admin GUI?
> Or shall I create a “Group Profile” via the Django Admin GUI and set all
> layers, that should be visible after registration to this group? But then,
> how would I enable all newly registered users to automatically belong to
> this group?
> Seems like a very simple thing  I would need, but somehow I don’t
> understand the preferred Geonode logic to get there. Any help is greatly
> appreciated
> Oliver
> [image: cid:image002.png at 01CD642E.9C14BB50]
> [image: cid:image002.gif at 01CBBECE.B2C97A40]
> Oliver Buck
> MSc Environmental Science
> E F T A S    Fernerkundung
> Technologietransfer GmbH
> Oststraße 2-18
> 48145 Münster
> Fon: +49 251 13307-57     E-Mail: oliver.buck at eftas.com
> Fax: +49 251 13307-33   Web:   http://www.eftas.com
> Geschäftsführer:
> Dipl.-Ing. Georg Altrogge
> Sitz der Gesellschaft: Münster
> Amtsgericht Münster, HRB 2999
> USt.-IdNr. DE 126038986
> [image: cid:image006.png at 01CD642E.9C14BB50]
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.*
> * This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.*
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/4df69acc/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/4df69acc/attachment-0003.png>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/4df69acc/attachment-0001.gif>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/4df69acc/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/4df69acc/attachment-0005.png>
More information about the geonode-users mailing list
