[GeoNode-users] Set layer visibility to registered users
EFTAS Oliver Buck oliver.buck at eftas.com
Mon Oct 21 04:20:21 PDT 2019
Thanks Alessio,
we checked out the latest Genode Version (2.10.x) as of 08.10.2019.
Did this feature come in later?
Thanks
Oliver
Von: Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it]
Gesendet: Montag, 21. Oktober 2019 12:39
An: EFTAS Oliver Buck
Cc: geonode-users at lists.osgeo.org
Betreff: Re: [GeoNode-users] Set layer visibility to registered users
by updating to the latest version of GeoNode, you will have a new group available, automatically created at initialization time, called "Registered Users".
You will be able to select this group in order to set the objects permissions.
Il giorno lun 21 ott 2019 alle ore 12:31 EFTAS Oliver Buck <oliver.buck at eftas.com<mailto:oliver.buck at eftas.com>> ha scritto:
Dear all,
I am currently setting up a Geonode and would like to set the visibility of several layers according to the user being registered or not. This means some layers shall be visible only to registered users, while some shall be visible for all users.
What is the best way to set this up?
I found this setting http://docs.geonode.org/en/2.10.x/basic/settings/index.html#auto-assign-registered-members-to-registered-members-group-name , but are not sure, if this is what I need? Do I then have to create a “Registered Users” group via the Django Admin GUI?
Or shall I create a “Group Profile” via the Django Admin GUI and set all layers, that should be visible after registration to this group? But then, how would I enable all newly registered users to automatically belong to this group?
Seems like a very simple thing  I would need, but somehow I don’t understand the preferred Geonode logic to get there. Any help is greatly appreciated
Oliver
[cid:image002.gif at 01CBBECE.B2C97A40]
Oliver Buck
MSc Environmental Science
E F T A S    Fernerkundung
Technologietransfer GmbH
Oststraße 2-18
48145 Münster
Fon: +49 251 13307-57     E-Mail: oliver.buck at eftas.com<mailto:oliver.buck at eftas.com>
Fax: +49 251 13307-33   Web:   http://www.eftas.com<http://www.eftas.com/>
Geschäftsführer:
Dipl.-Ing. Georg Altrogge
Sitz der Gesellschaft: Münster
Amtsgericht Münster, HRB 2999
USt.-IdNr. DE 126038986
[cid:image006.png at 01CD642E.9C14BB50]
[cid:image004.png at 01D58812.08E80570]
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/3126076f/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/3126076f/attachment-0003.png>
Type: image/gif
Desc: image002.gif
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/3126076f/attachment-0001.gif>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/3126076f/attachment-0004.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/3126076f/attachment-0005.png>
More information about the geonode-users mailing list
