[GeoNode-users] Set layer visibility to registered users
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Oct 21 03:38:41 PDT 2019
by updating to the latest version of GeoNode, you will have a new group
available, automatically created at initialization time, called "Registered
Users".
You will be able to select this group in order to set the objects
permissions.
Il giorno lun 21 ott 2019 alle ore 12:31 EFTAS Oliver Buck <
oliver.buck at eftas.com> ha scritto:
> Dear all,
> I am currently setting up a Geonode and would like to set the visibility
> of several layers according to the user being registered or not. This means
> some layers shall be visible only to registered users, while some shall be
> visible for all users.
> What is the best way to set this up?
> I found this setting
> http://docs.geonode.org/en/2.10.x/basic/settings/index.html#auto-assign-registered-members-to-registered-members-group-name
> , but are not sure, if this is what I need? Do I then have to create a
> “Registered Users” group via the Django Admin GUI?
> Or shall I create a “Group Profile” via the Django Admin GUI and set all
> layers, that should be visible after registration to this group? But then,
> how would I enable all newly registered users to automatically belong to
> this group?
> Seems like a very simple thing I would need, but somehow I don’t
> understand the preferred Geonode logic to get there. Any help is greatly
> appreciated
> Oliver
> [image: cid:image002.png at 01CD642E.9C14BB50]
> [image: cid:image002.gif at 01CBBECE.B2C97A40]
> Oliver Buck
> MSc Environmental Science
> E F T A S Fernerkundung
> Technologietransfer GmbH
> Oststraße 2-18
> 48145 Münster
> Fon: +49 251 13307-57 E-Mail: oliver.buck at eftas.com
> Fax: +49 251 13307-33 Web: http://www.eftas.com
> Geschäftsführer:
> Dipl.-Ing. Georg Altrogge
> Sitz der Gesellschaft: Münster
> Amtsgericht Münster, HRB 2999
> USt.-IdNr. DE 126038986
> [image: cid:image006.png at 01CD642E.9C14BB50]
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/2272bc7e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/2272bc7e/attachment-0003.png>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/2272bc7e/attachment-0001.gif>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/2272bc7e/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191021/2272bc7e/attachment-0005.png>
More information about the geonode-users
