[GeoNode-users] Installation process (Matheus Ximenes)
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Thu Oct 24 09:46:26 PDT 2019
Hi Matheus,
There is only one geonode which is:
https://github.com/GeoNode/geonode
As Django app you can start it with Django's inbuilt webserver aka runserver. This is actually
what the Development setup does by use of paver.
Here sqlite and jetty are used to give you a quick setup. By changing your configuration to
use more stable components like postgis, nginx and tomcat you will end with a "production" environment.
As we should not change the core there is geocode-project which install geonode core as dependency.
Doing so you can overwrite stuff.
Docker ... is a containerized service: Read here to get the main idea:
https://en.wikipedia.org/wiki/Docker_(software)
In case you do not want to setup geonode for production manually you can use the docker compositions
for geonode. Here we have to flavours. Geonode main docker setup and SPC. The later is a quite nice
alternative composition. However, both use the geonode core as their basis.
All togetherr don't get confused ;)
Hope this helps.
Cheers,
Toni
> Good afternoon,
> I come through this, asking for help installing GeoNode, there are conflicting concepts in my head and I was wondering if you could help me. I have great questions about the connection that exists between GeoNode Core, Project GeoNode and SPCGeoNode is it necessary to perform all installations? Does one depend on the other? I was following the installation of GeoNode Core, but right now:
> Install and enable HTTPS secured connection through the Let's Encrypt provider
> I encountered serious problems with these let's encrypt certificates, after this step the application would already be running publicly? If so, is it recommended, as adjustments are still missing?
> Any questions answered will be of great help.
> see you later
> Matheus Ximenes
More information about the geonode-users
