[GeoNode-users] R: migration suggestions
Eugenio Trumpy
frippe12573 at hotmail.com
Fri Oct 25 07:58:55 PDT 2019
Hi Alessio,
thank you for your prompt answer. However, I have a doubts(I apologise if it is stupid) about your hints:
1. for metadata do you mean the postgresql db? in case of yes, what do you mean with 'no much', I have 42 layers in 'geonode_data' and 20 maps 116 layers and a couple of users in 'geonode' pgsql dbs. So can I dump and restore both databases? or the db structure is changed, so that I need a special procedure?
2. If I port the data only by geoserver, what I have after the updatelayers in the pgsql dbs? no metadata I presume, or only basic info taken from the old geoserver?
3. What about the porting of the look and feel of the sites I have? just copy the codes?
Thanks a lot,
Eugenio
Da: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
Inviato: venerdì 25 ottobre 2019 16:27
A: Eugenio Trumpy <frippe12573 at hotmail.com>
Cc: geonode-users at lists.osgeo.org <geonode-users at lists.osgeo.org>
Oggetto: Re: [GeoNode-users] migration suggestions
Hello Eugenio,
in the case you have no much metadata to configure and few users, my *hot* suggestion is to pass through GeoServer in order to port your datasets.
So the steps would be the following ones:
1. Setup a new GeoServer 2.15.2 ( https://build.geo-solutions.it/geonode/geoserver/latest/geoserver-2.15.2.war )
2. Transfer the Data Dir from the old GeoServer to the new one (I strongly suggest to backport **only** the workspace, datasets and styles, not the security subsystem)
3. Setup the new GeoNode instance
4. Run the "updatelayers" management command (see http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#management-command-updatelayers )
5. Update manually the missing permissions and metadata
Il giorno ven 25 ott 2019 alle ore 16:08 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>> ha scritto:
Dear all,
I have a running geonode at version 2.4 dev20160525015826 configured as multisite in a ubuntu server 16.04.6 LTS.
The system administrator suggested me to update the server OS to 18.04.3 LTS for many reasons that are not the topic of this email.
I would like to know if there are suggested procedures to migrate my multisite project, data, ... to a newer version of geonode
(the most update seems to be the vs.2.10).
Just to let you know, for the previous installation I followed the custom installation,
because in the server were already running postgresql, tomcat, and so on...
Moreover, as said, I set the project to be used as multi-sites.
So I need:
1. to install a fresh geonode version
2. set-up the multi-sites
3. dump the data from version 2.4
4. load the data in the new version
Any hints or recommendations?
Thanks,
Eugenio
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191025/9fb6c38f/attachment.html>
More information about the geonode-users
