[GeoNode-users] migration suggestions
    Alessio Fabiani
    alessio.fabiani at geo-solutions.it
    Fri Oct 25 07:27:53 PDT 2019
Hello Eugenio,
in the case you have no much metadata to configure and few users, my *hot*
suggestion is to pass through GeoServer in order to port your datasets.
So the steps would be the following ones:
1. Setup a new GeoServer 2.15.2 (
https://build.geo-solutions.it/geonode/geoserver/latest/geoserver-2.15.2.war
2. Transfer the Data Dir from the old GeoServer to the new one (I strongly
suggest to backport **only** the workspace, datasets and styles, not the
security subsystem)
3. Setup the new GeoNode instance
4. Run the "updatelayers" management command (see
http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#management-command-updatelayers
5. Update manually the missing permissions and metadata
Il giorno ven 25 ott 2019 alle ore 16:08 Eugenio Trumpy <
frippe12573 at hotmail.com> ha scritto:
> Dear all,
> I have a running geonode at version 2.4 dev20160525015826 configured as
> multisite in a ubuntu server 16.04.6 LTS.
> The system administrator suggested me to update the server OS to 18.04.3
> LTS for many reasons that are not the topic of this email.
> I would like to know if there are suggested procedures to migrate my
> multisite project, data, ... to a newer version of geonode
> (the most update seems to be the vs.2.10).
> Just to let you know, for the previous installation I followed the custom
> installation,
> because in the server were already running postgresql, tomcat, and so on...
> Moreover, as said, I set the project to be used as multi-sites.
> So I need:
>    1. to install a fresh geonode version
>    2. set-up the multi-sites
>    3. dump the data from version 2.4
>    4. load the data in the new version
> Any hints or recommendations?
> Thanks,
> Eugenio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191025/8a587568/attachment-0001.html>
More information about the geonode-users
