[GeoNode-users] Importing layer for remote service queued indefinitely (Celery not configured?)
Amedeo Fadini
amefad at gmail.com
Fri Oct 25 10:05:14 PDT 2019
Hi Alessio,
Il giorno ven 25 ott 2019 alle ore 16:29 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Hi Amedeo,
> if the queue stucks, most probably there's a celery configuration issue.
> Are you using the default memory broker?
> I think so, idon't even know where to configure the memory broker...
Ok found. I get the docker-compose.yml [0] from geonode project branch 2.8
and i see
CELERY_CMD: celery worker --app={{project_name}}.celeryapp:app
--broker=amqp://guest:guest@rabbitmq:5672/ -B -l INFO
I'll start to study the celery userguide is all on this url?
https://docs.celeryproject.org/en/latest/userguide/configuration.html
Amedeo
[0] https://github.com/CNR-ISMAR/iws/blob/master/docker-compose.yml
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191025/ab59d936/attachment.html>
More information about the geonode-users
