[GeoNode-users] UNABLE TO LOAD METADATA FROM GEONETWORK
XAVIER RAYO SARRIAS
xrayo at utm.csic.es
Mon Oct 28 03:11:14 PDT 2019
Thank you very much for your answer, Alessio.
I was expecting something like that, but couldn't find it.
I think I will try to re-upload all my layers to geonode in order to have them in both systems.
After trying it with some samples, I can’t find them in geonetwork and don’t know why. Is there a way to know that geonode is properly connected and configured to work with geonetwork?
Thank you very much!
> El 25 oct 2019, a les 16:46, Alessio Fabiani <alessio.fabiani at geo-solutions.it> va escriure:
> Hi XAVIER,
> just to be clear, GeoNode won't get anything from GeoNetwork. It will just add metadata records to GeoNetwork and read them when you ask, from GeoNode, to download the metadata.
> So, if you expect to see the layers configured into GeoNetwork ingested into GeoNode, this feature is not implemented unfortunately.
> Il giorno ven 25 ott 2019 alle ore 09:42 XAVIER RAYO SARRIAS <xrayo at utm.csic.es <mailto:xrayo at utm.csic.es>> ha scritto:
> Hi all,
> I’ve been trying this for a few weeks with no success.
> We have server with geonetwork already running and with many metadata on it.
> Now I have installed geonode and uploaded some data which I would like to merge with the metadata.
> I have followed the instructions here : http://docs.geonode.org/en/2.8.1/tutorials/admin/csw_settings/index.html <http://docs.geonode.org/en/2.8.1/tutorials/admin/csw_settings/index.html> modifying the settings.py file pointing it to our geonetwork server:
> # CSW settings
> CATALOGUE = {
> 'default': {
> # The underlying CSW implementation
> # default is pycsw in local mode (tied directly to GeoNode Django DB)
> #'ENGINE': 'geonode.catalogue.backends.pycsw_local',
> # pycsw in non-local mode
> # 'ENGINE': 'geonode.catalogue.backends.pycsw_http',
> # GeoNetwork opensource
> 'ENGINE': 'geonode.catalogue.backends.geonetwork',
> # deegree and others
> # 'ENGINE': 'geonode.catalogue.backends.generic',
> # The FULLY QUALIFIED base url to the CSW instance for this GeoNode
> #'URL': urljoin(SITEURL, '/catalogue/csw'),
> 'URL': 'http://myserver/geonetwork/srv/en/csw <http://myserver/geonetwork/srv/en/csw>',
> # 'URL': 'http://localhost:8080/deegree-csw-demo-3.0.4/services <http://localhost:8080/deegree-csw-demo-3.0.4/services>',
> # login credentials (for GeoNetwork)
> 'USER': ‘admin',
> 'PASSWORD': ‘mypassword',
> # 'ALTERNATES_ONLY': True,
> Am I doing something wrong or missing something?
> What should I do to connect my geonode layers to use the metadata from our geonetwork server?
> Thank very much for your help!
> geonode-users mailing list
> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/geonode-users <https://lists.osgeo.org/mailman/listinfo/geonode-users>
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V <http://goo.gl/it488V> for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it <http://www.geo-solutions.it/>
> http://twitter.com/geosolutions_it <http://twitter.com/geosolutions_it>
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191028/f3c53801/attachment-0001.html>
More information about the geonode-users
