[GeoNode-users] Issue with GeoNode Layer Scale
Kabatha Patrick kpparto at gmail.com
Fri Sep 13 10:23:03 PDT 2019
I'm experiencing a similar problem here with Geonode 2.10.1 installed in
ubuntu 18.04.
My layers are out of range and need to zoom in manually. Are there any
settings required to fix this?
[image: image.png]
Any recommendations?
Thanks,
Patrick.
On Tue, Jan 15, 2019 at 3:49 AM MDG DEE <kula009 at gmail.com> wrote:
> Hello,
> I deployed a GeoNode 2.8 (installed via quick installer) on an AWS EC2
> instance. And it is connected to a data store that is running on an AWS RDS
> right now.
> After adding layers, I noticed that the default scale is messed up, which
> is zoomed at "1:1066"(the maximum scale GeoNode could handle? ). So I have
> to manually fix the correct extent.
> Once thing I could think of is setting the bounding box. However, when
> publishing layers, I was sure that the bounding boxes were set correctly,
> which were computed from the data.
> How could I set the layer scale in accordance with the layer itself? Where
> do I find the related settings?
> Thank you very much!
> Ran
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GIS Analyst
Geography & Ecology.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190913/9c4637b4/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190913/9c4637b4/attachment-0001.png>
More information about the geonode-users mailing list
