[GeoNode-users] Issue with GeoNode Layer Scale
Alessio Fabiani
alessio.fabiani at gmail.com
Fri Sep 13 14:35:32 PDT 2019
Please update the mapstore client library to the most recent version
*pip install django-geonode-mapstore-client==1.4.1 --upgrade*
Il ven 13 set 2019, 19:23 Kabatha Patrick <kpparto at gmail.com> ha scritto:
> Hi,
> I'm experiencing a similar problem here with Geonode 2.10.1 installed in
> ubuntu 18.04.
> My layers are out of range and need to zoom in manually. Are there any
> settings required to fix this?
> [image: image.png]
> Any recommendations?
> Thanks,
> Patrick.
> On Tue, Jan 15, 2019 at 3:49 AM MDG DEE <kula009 at gmail.com> wrote:
>> Hello,
>> I deployed a GeoNode 2.8 (installed via quick installer) on an AWS EC2
>> instance. And it is connected to a data store that is running on an AWS RDS
>> right now.
>> After adding layers, I noticed that the default scale is messed up, which
>> is zoomed at "1:1066"(the maximum scale GeoNode could handle? ). So I have
>> to manually fix the correct extent.
>> Once thing I could think of is setting the bounding box. However, when
>> publishing layers, I was sure that the bounding boxes were set correctly,
>> which were computed from the data.
>> How could I set the layer scale in accordance with the layer itself?
>> Where do I find the related settings?
>> Thank you very much!
>> Ran
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GIS Analyst
> Geography & Ecology.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190913/f9eab36d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190913/f9eab36d/attachment-0001.png>
More information about the geonode-users
