[GeoNode-users] Geonode url under /geonode path
Gus MacAulay
gusmacaulay at gmail.com
Fri Apr 3 17:28:53 PDT 2020
Hi Teresa,
I didn't modify the urls.py - I did set the docker environment variables
such as SITEURL and GEONODE_LB_HOST to point to the /geonode/ domain. My
api is available under /geonode/api
Regards
Gus
On Thu, 2 Apr 2020 at 22:08, Teresa Fazio <fazio at planetek.it> wrote:
> Hi Gus,
> Thanks for your replay.
> I’m using spcgeonode on docker too.
> I configure spcgeonode.conf file under nginx to point to /geonode location
> and I view geonode homepage correctly.
> Then I changed urls.py file of geonode directory to map other links like
> layers, users,…pages.
> Now I'm trying to figure out how to modify other urls to make everything
> work.
> For example api urls to get layers list.
> Can you help me?
> Thanks in advance.
> Teresa Fazio
> Technical Specialist
> Government & Security SBU
> Planetek Italia S.r.l.
> Via Massaua, 12
> I-70132 Bari BA - Italy
> Tel. +39 080 9644200
> http://www.planetek.it
> *From:* Silvia Salsone
> *Sent:* mercoledì 1 aprile 2020 12:38
> *To:* Teresa Fazio <fazio at planetek.it>
> *Subject:* I: [GeoNode-users] Geonode url under /geonode path
> *Da:* geonode-users <geonode-users-bounces at lists.osgeo.org> per conto di
> Gus MacAulay <gusmacaulay at gmail.com>
> *Inviato:* venerdì 27 marzo 2020 03:31
> *A:* geonode-users at lists.osgeo.org <geonode-users at lists.osgeo.org>
> *Oggetto:* Re: [GeoNode-users] Geonode url under /geonode path
> Hi Teresa,
> I was able to do this with nginx configuration. I am running on docker so
> I had to create a slightly customised nginx docker container.
> The nginx.conf needs to have a geonode entry something like this - it's
> not perfect but it works for my purpose;
> location /geonode {
> etag off;
> expires 0;
> rewrite /geonode(.+) $1 break;
> include uwsgi_params;
> uwsgi_pass uwsgi://django:8000;
> add_header Access-Control-Allow-Credentials false;
> add_header Access-Control-Allow-Headers "Content-Type, Accept, Authorization, Origin, User-Agent";
> add_header Access-Control-Allow-Methods "GET, POST, PUT, PATCH, OPTIONS";
> if ($request_method = OPTIONS) {
> add_header Access-Control-Allow-Headers "Authorization, Content-Type, Accept";
> add_header Access-Control-Allow-Credentials true;
> add_header Content-Length 0;
> add_header Content-Type text/plain;
> add_header Access-Control-Max-Age 1728000;
> return 200;
> client_max_body_size 1500M;
> client_body_buffer_size 2M;
> proxy_redirect http://django:8000 /geonode;
> On Wed, 25 Mar 2020 at 22:15, Francesco Bartoli <xbartolone at gmail.com>
> wrote:
> Hi Teresa,
> this would heavily affect the routing of the django application and its
> configuration. You can try to adapt it within a geonode-project but I can’t
> recommend.
> I don’t know if others have some different experiences.
> Hope this helps
> Francesco
> Il 25 mar 2020, 10:12 +0100, Teresa Fazio <fazio at planetek.it>, ha scritto:
> Hi all,
> How can I publish my geonode app under url like
> https://mydomain.it/geonode
> Thanks in advance
> Teresa Fazio
> Via Massaua, 12
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200404/b028a1ef/attachment-0001.html>
More information about the geonode-users
