[GeoNode-users] Geonode Windows Installation Error
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Dec 3 06:23:38 PST 2020
It looks like a wrong GDAL installation.
Il giorno gio 3 dic 2020 alle ore 12:01 Anand Jadhav <ajadhav4 at gmail.com>
ha scritto:
> Dear All,
> Below is the installation error code on Windows as per the documentation.
> The error occurred while executing the command
> pip install -r requirements.txt --upgrade --no-cache --no-cache-dir
> error as following:-
> Collecting pyyaml>=4.2b1
> Downloading PyYAML-5.3.1-cp37-cp37m-win_amd64.whl (216 kB)
> |████████████████████████████████| 216 kB 6.4 MB/s
> Collecting requests==2.25.0
> Downloading requests-2.25.0-py2.py3-none-any.whl (61 kB)
> |████████████████████████████████| 61 kB ...
> Collecting requests-toolbelt==0.9.1
> Downloading requests_toolbelt-0.9.1-py2.py3-none-any.whl (54 kB)
> |████████████████████████████████| 54 kB 1.2 MB/s
> Collecting Shapely==1.6.3
> Downloading Shapely-1.6.3.tar.gz (223 kB)
> |████████████████████████████████| 223 kB 6.8 MB/s
> ERROR: Command errored out with exit status 1:
> command: 'c:\working\venv\scripts\python.exe' -c 'import sys,
> setuptools, tokenize; sys.argv[0] =
> '"'"'C:\\Users\\User\\AppData\\Local\\Temp\\pip-install-36744eq2\\shapely_f68ba02e25af41acb89913bd54991419\\setup.py'"'"';
> __file__='"'"'C:\\Users\\User\\AppData\\Local\\Temp\\pip-install-36744eq2\\shapely_f68ba02e25af41acb89913bd54991419\\setup.py'"'"';f=getattr(tokenize,
> '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"',
> '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))'
> egg_info --egg-base
> 'C:\Users\User\AppData\Local\Temp\pip-pip-egg-info-nt4zt4mb'
> cwd:
> C:\Users\User\AppData\Local\Temp\pip-install-36744eq2\shapely_f68ba02e25af41acb89913bd54991419\
> Complete output (9 lines):
> Traceback (most recent call last):
> File "<string>", line 1, in <module>
> File
> "C:\Users\User\AppData\Local\Temp\pip-install-36744eq2\shapely_f68ba02e25af41acb89913bd54991419\setup.py",
> line 80, in <module>
> from shapely._buildcfg import geos_version_string, geos_version, \
> File
> "C:\Users\User\AppData\Local\Temp\pip-install-36744eq2\shapely_f68ba02e25af41acb89913bd54991419\shapely\_buildcfg.py",
> line 200, in <module>
> lgeos = CDLL("geos_c.dll")
> File "c:\program files\python37\lib\ctypes\__init__.py", line 364,
> in __init__
> self._handle = _dlopen(self._name, mode)
> OSError: [WinError 126] The specified module could not be found
> ERROR: Command errored out with exit status 1: python setup.py egg_info
> Check the logs for full command output.
> Please help how to resolve this.
> Best regards,
> Anand
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201203/a65192f3/attachment-0001.html>
More information about the geonode-users
