[GeoNode-users] Performance issues with tiled layers
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Feb 10 06:53:31 PST 2020
Dear Maxime,
it could be probably a performance issue of the MapStore client which has
been resolved recently. It appeared with the new versions of Google Chrome
especially.
Any chance to upgrade the django-mapstore-adapter and
geonode-mapstore-client pip dependencies as follows?
pip install django-mapstore-adapter==1.0.17
pip install django-geonode-mapstore-client==1.4.8
P.S.: remember also that OpenStreeMap lowers down your available
bandwidth in case too much requests are issues from the same IP address.
Try maybe with different backgrounds.
Regards,
Alessio.
Il giorno lun 10 feb 2020 alle ore 14:43 Maxime Audet-Roberge <
maximeaudetr at hotmail.com> ha scritto:
> Good day GeoNode users,
> I am running GeoNode project 2.10.1 on an Ubuntu 18.04 machine. GeoServer
> is installed on a different machine on the same server. Everything is
> working well. However, I am having performance issues with the display of
> data in MapStore when the layers are tiled. For example, I have a map that
> contains 15 layers. This map takes about 40 seconds to load when the layers
> are tiled and takes less than 5 seconds to load when the single tile option
> is activated. Cache creation is enabled and seems to work (tiles are saved
> in my gwc directory).
> I always thought that using tiles would improve the speed of layer display
> but this is not the case on my installation.
> Do you have any recommendations to improve the performance of my GeoServer
> installation?
> Thanks a lot!
> Maxime
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200210/77461faa/attachment.html>
More information about the geonode-users mailing list
