[GeoNode-users] Performance issues with tiled layers
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Feb 10 08:27:32 PST 2020
Uhm, currently not.
Do you have any public map that we can use in order to inspect the request?
Or otherwise, can you send some netlog of the time consuming requests?
Il giorno lun 10 feb 2020 alle ore 17:00 Maxime Audet-Roberge <
maximeaudetr at hotmail.com> ha scritto:
> Hi Alessio,
> Thanks for your quick answer. I update django-mapstore-adapter from 1.0.12
> to 1.0.17 and django-geonode-mapstore-client from 1.4.6 to 1.4.8 and I dont
> see a difference, it still takes about 40-45 seconds to load the map. I
> also tried without any background and there is no difference.
> Any other ideas?
> Thanks a lot!
> Maxime
> Télécharger Outlook pour Android <https://aka.ms/ghei36>
> *From:* Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> *Sent:* Monday, February 10, 2020 9:53:31 AM
> *To:* Maxime Audet-Roberge <maximeaudetr at hotmail.com>
> *Cc:* geonode-users at lists.osgeo.org <geonode-users at lists.osgeo.org>
> *Subject:* Re: [GeoNode-users] Performance issues with tiled layers
> Dear Maxime,
> it could be probably a performance issue of the MapStore client which has
> been resolved recently. It appeared with the new versions of Google Chrome
> especially.
> Any chance to upgrade the django-mapstore-adapter and
> geonode-mapstore-client pip dependencies as follows?
> pip install django-mapstore-adapter==1.0.17
> pip install django-geonode-mapstore-client==1.4.8
> P.S.: remember also that OpenStreeMap lowers down your available
> bandwidth in case too much requests are issues from the same IP address.
> Try maybe with different backgrounds.
> Regards,
> Alessio.
> Il giorno lun 10 feb 2020 alle ore 14:43 Maxime Audet-Roberge <
> Good day GeoNode users,
> I am running GeoNode project 2.10.1 on an Ubuntu 18.04 machine. GeoServer
> is installed on a different machine on the same server. Everything is
> working well. However, I am having performance issues with the display of
> data in MapStore when the layers are tiled. For example, I have a map that
> contains 15 layers. This map takes about 40 seconds to load when the layers
> are tiled and takes less than 5 seconds to load when the single tile option
> is activated. Cache creation is enabled and seems to work (tiles are saved
> in my gwc directory).
> I always thought that using tiles would improve the speed of layer display
> but this is not the case on my installation.
> Do you have any recommendations to improve the performance of my GeoServer
> installation?
> Thanks a lot!
> Maxime
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200210/82fdaeda/attachment-0001.html>
More information about the geonode-users
