[GeoNode-users] Performance issues with tiled layers
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Feb 12 00:53:54 PST 2020
Hi all,
yes the option are saved into the map configuration.
About the performance issues, I guess it need further investigation. Could
be an issue on MapStore side.
Let's open an issue for this.
Il giorno mar 11 feb 2020 alle ore 17:15 Maxime Audet-Roberge <
maximeaudetr at hotmail.com> ha scritto:
> Hi Florian,
> I just reopened the single tile map and the single tile checkbox is still
> checked for each layer. Also, when I look at the network monitor in Firefox
> I see only 1 request per layer instead of 26 per layer for a tiled layer.
> Cheers!
> Maxime
> Télécharger Outlook pour Android <https://aka.ms/ghei36>
> *From:* Florian Hoedt <florian.hoedt at thuenen.de>
> *Sent:* Tuesday, February 11, 2020 10:24:28 AM
> *To:* Maxime Audet-Roberge <maximeaudetr at hotmail.com>
> *Cc:* Alessio Fabiani <alessio.fabiani at geo-solutions.it>; geonode-users <
> geonode-users at lists.osgeo.org>
> *Subject:* Re: [GeoNode-users] Performance issues with tiled layers
> Hello Maxime,
> AFAIK the single tile / tiled option is not saved in the map, yet.
> Currently both of your maps default to tiled.
> Please correct me if I am wrong Alessio
> Florian
> MSc Florian Hoedt
> Coordinator Geoinformatics | OpenData Representative
> Thünen Institute, Centre for Information Management
> Bundesallee 44
> 38116 Braunschweig
> Tel: +49 531 596-1428
> Fax: +49 531 596-1499
> Mail: florian.hoedt at thuenen.de
> Web: www.thuenen.de
> The Johann Heinrich von Thünen Institute, Federal Research Institute for
> Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists
> of 14 specialized institutes that carry out research and provide policy
> advice in the fields of economy, ecology and technology.
> *Von: *"Maxime Audet-Roberge" <maximeaudetr at hotmail.com>
> *An: *"Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
> *CC: *"Alessio Fabiani" <alessio.fabiani at geo-solutions.it>,
> "geonode-users" <geonode-users at lists.osgeo.org>
> *Gesendet: *Dienstag, 11. Februar 2020 15:54:33
> *Betreff: *Re: [GeoNode-users] Performance issues with tiled layers
> Hi Alessio,
> I just created 2 maps on the master demo site, 1 with tiled layers and 1
> with the single tiles option activated. Both contains the same layers (13
> layers).
> Tiled: https://master.demo.geonode.org/maps/2309/view
> Single tiles: https://master.demo.geonode.org/maps/2312/view
> On my computer, the tiled map takes about 35 seconds to load and the
> single tiles map takes 2 or 3 seconds. It's pretty much the same
> performances that I have with my installation.
> I can try to extrack some network stats from my installation if you need.
> Again, thanks a lot for your support!
> Maxime
> *From:* Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> *Sent:* Monday, February 10, 2020 11:27:32 AM
> geonode-users at lists.osgeo.org <geonode-users at lists.osgeo.org>
> Uhm, currently not.
> Do you have any public map that we can use in order to inspect the request?
> Or otherwise, can you send some netlog of the time consuming requests?
> Il giorno lun 10 feb 2020 alle ore 17:00 Maxime Audet-Roberge <
> Hi Alessio,
> Thanks for your quick answer. I update django-mapstore-adapter from 1.0.12
> to 1.0.17 and django-geonode-mapstore-client from 1.4.6 to 1.4.8 and I dont
> see a difference, it still takes about 40-45 seconds to load the map. I
> also tried without any background and there is no difference.
> Any other ideas?
> Thanks a lot!
> Maxime
> *Sent:* Monday, February 10, 2020 9:53:31 AM
> *Cc:* geonode-users at lists.osgeo.org <geonode-users at lists.osgeo.org>
> Dear Maxime,
> it could be probably a performance issue of the MapStore client which has
> been resolved recently. It appeared with the new versions of Google Chrome
> especially.
> Any chance to upgrade the django-mapstore-adapter and
> geonode-mapstore-client pip dependencies as follows?
> pip install django-mapstore-adapter==1.0.17
> pip install django-geonode-mapstore-client==1.4.8
> P.S.: remember also that OpenStreeMap lowers down your available
> bandwidth in case too much requests are issues from the same IP address.
> Try maybe with different backgrounds.
> Regards,
> Alessio.
> Il giorno lun 10 feb 2020 alle ore 14:43 Maxime Audet-Roberge <
> Good day GeoNode users,
> I am running GeoNode project 2.10.1 on an Ubuntu 18.04 machine. GeoServer
> is installed on a different machine on the same server. Everything is
> working well. However, I am having performance issues with the display of
> data in MapStore when the layers are tiled. For example, I have a map that
> contains 15 layers. This map takes about 40 seconds to load when the layers
> are tiled and takes less than 5 seconds to load when the single tile option
> is activated. Cache creation is enabled and seems to work (tiles are saved
> in my gwc directory).
> I always thought that using tiles would improve the speed of layer display
> but this is not the case on my installation.
> Do you have any recommendations to improve the performance of my GeoServer
> installation?
> Thanks a lot!
> Maxime
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200212/8f8f231f/attachment-0001.html>
More information about the geonode-users
