[GeoNode-users] Performance issues with tiled layers
Maxime Audet-Roberge
maximeaudetr at hotmail.com
Wed Feb 12 04:49:56 PST 2020
Hi Alessio,
I can do that. Do you want me to open the issue in the geonode mapstore client repo or in the mapstore2 repo?
Also, is it possible to change the configuration of mapstore to use single tiles by default every time we create a map?
Cheers!
Maxime
Télécharger Outlook pour Android<https://aka.ms/ghei36>
From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
Sent: Wednesday, February 12, 2020 3:53:54 AM
To: Maxime Audet-Roberge <maximeaudetr at hotmail.com>
Cc: Florian Hoedt <florian.hoedt at thuenen.de>; Alessio Fabiani <alessio.fabiani at geo-solutions.it>; geonode-users <geonode-users at lists.osgeo.org>
Subject: Re: [GeoNode-users] Performance issues with tiled layers
Hi all,
yes the option are saved into the map configuration.
About the performance issues, I guess it need further investigation. Could be an issue on MapStore side.
Let's open an issue for this.
Il giorno mar 11 feb 2020 alle ore 17:15 Maxime Audet-Roberge <maximeaudetr at hotmail.com<mailto:maximeaudetr at hotmail.com>> ha scritto:
Hi Florian,
I just reopened the single tile map and the single tile checkbox is still checked for each layer. Also, when I look at the network monitor in Firefox I see only 1 request per layer instead of 26 per layer for a tiled layer.
Cheers!
Maxime
From: Florian Hoedt <florian.hoedt at thuenen.de<mailto:florian.hoedt at thuenen.de>>
Sent: Tuesday, February 11, 2020 10:24:28 AM
To: Maxime Audet-Roberge <maximeaudetr at hotmail.com<mailto:maximeaudetr at hotmail.com>>
Cc: Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>>; geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>
Hello Maxime,
AFAIK the single tile / tiled option is not saved in the map, yet. Currently both of your maps default to tiled.
Please correct me if I am wrong Alessio
Florian
MSc Florian Hoedt
Coordinator Geoinformatics | OpenData Representative
Thünen Institute, Centre for Information Management
Bundesallee 44
38116 Braunschweig
Tel: +49 531 596-1428
Fax: +49 531 596-1499
Mail: florian.hoedt at thuenen.de<mailto:florian.hoedt at thuenen.de>
Web: www.thuenen.de<http://www.thuenen.de>
The Johann Heinrich von Thünen Institute, Federal Research Institute for Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists of 14 specialized institutes that carry out research and provide policy advice in the fields of economy, ecology and technology.
Von: "Maxime Audet-Roberge" <maximeaudetr at hotmail.com<mailto:maximeaudetr at hotmail.com>>
An: "Alessio Fabiani" <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>>
CC: "Alessio Fabiani" <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>>, "geonode-users" <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>
Gesendet: Dienstag, 11. Februar 2020 15:54:33
Betreff: Re: [GeoNode-users] Performance issues with tiled layers
Hi Alessio,
I just created 2 maps on the master demo site, 1 with tiled layers and 1 with the single tiles option activated. Both contains the same layers (13 layers).
Tiled: https://master.demo.geonode.org/maps/2309/view
Single tiles: https://master.demo.geonode.org/maps/2312/view
On my computer, the tiled map takes about 35 seconds to load and the single tiles map takes 2 or 3 seconds. It's pretty much the same performances that I have with my installation.
I can try to extrack some network stats from my installation if you need.
Again, thanks a lot for your support!
Maxime
From: Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>>
Sent: Monday, February 10, 2020 11:27:32 AM
Cc: Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>>; geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org> <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>
Uhm, currently not.
Do you have any public map that we can use in order to inspect the request?
Or otherwise, can you send some netlog of the time consuming requests?
Il giorno lun 10 feb 2020 alle ore 17:00 Maxime Audet-Roberge <maximeaudetr at hotmail.com<mailto:maximeaudetr at hotmail.com>> ha scritto:
Hi Alessio,
Thanks for your quick answer. I update django-mapstore-adapter from 1.0.12 to 1.0.17 and django-geonode-mapstore-client from 1.4.6 to 1.4.8 and I dont see a difference, it still takes about 40-45 seconds to load the map. I also tried without any background and there is no difference.
Any other ideas?
Thanks a lot!
Maxime
Sent: Monday, February 10, 2020 9:53:31 AM
Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org> <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>
Dear Maxime,
it could be probably a performance issue of the MapStore client which has been resolved recently. It appeared with the new versions of Google Chrome especially.
Any chance to upgrade the django-mapstore-adapter and geonode-mapstore-client pip dependencies as follows?
pip install django-mapstore-adapter==1.0.17
pip install django-geonode-mapstore-client==1.4.8
P.S.: remember also that OpenStreeMap lowers down your available bandwidth in case too much requests are issues from the same IP address. Try maybe with different backgrounds.
Regards,
Alessio.
Il giorno lun 10 feb 2020 alle ore 14:43 Maxime Audet-Roberge <maximeaudetr at hotmail.com<mailto:maximeaudetr at hotmail.com>> ha scritto:
Good day GeoNode users,
I am running GeoNode project 2.10.1 on an Ubuntu 18.04 machine. GeoServer is installed on a different machine on the same server. Everything is working well. However, I am having performance issues with the display of data in MapStore when the layers are tiled. For example, I have a map that contains 15 layers. This map takes about 40 seconds to load when the layers are tiled and takes less than 5 seconds to load when the single tile option is activated. Cache creation is enabled and seems to work (tiles are saved in my gwc directory).
I always thought that using tiles would improve the speed of layer display but this is not the case on my installation.
Do you have any recommendations to improve the performance of my GeoServer installation?
Thanks a lot!
Maxime
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
@alfa7691
GeoSolutions S.A.S.
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200212/0921279b/attachment-0001.html>
More information about the geonode-users
