[GeoNode-users] Background layers in the print tool
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Feb 18 07:08:32 PST 2020
Hello Maxime,
unfortunately at this time, it is normal since the printing plugin relies
on a GeoServer endpoint.
We are planning to improve the printing backend by allowing GeoNode to
produce the PDF directly, but this will require some time and resources.
Il giorno ven 14 feb 2020 alle ore 15:23 Maxime Audet-Roberge <
maximeaudetr at hotmail.com> ha scritto:
> Good day GeoNode users,
> I have a few questions regarding the print tool in GeoNode, more
> specifically about printing backgrounds. It seems that only a few
> backgrounds layers (Open Street Map and Sentinel-2 Cloudless) are printed.
> The others I tried are not displayed, there is only a white background. I
> tried Open Topo Map, HERE maps, Stamen and a few others without success.
> I see in the json file that is sent in the post request that the layer
> list is empty for all the background layers that are not displayed while
> OSM and Sentinel are in the layer list when they are selected.
> Is it normal that only 2 background layers are printed? Do you guys
> managed to print other backgrounds? If so, is there a list of printable
> backgrounds?
> Thanks a lot!
> Maxime
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200218/daf155fa/attachment.html>
More information about the geonode-users mailing list
