[GeoNode-users] uwsgi service won't start
1520 gis
juliermeopensourcedeveloper at gmail.com
Fri Jan 24 09:05:45 PST 2020
Right to target Alessio.
I appreciated your help.
Kind regards
Julierme
On Fri, Jan 24, 2020 at 1:55 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Julierme,
> typically this error is caused by the wrong path of the virtual
> environment.
> Please, double-check that this folder /home/geonode/.virtualenvs/geonode actually
> exits and contains the GeoNode virtual environment and packages.
> Il giorno ven 24 gen 2020 alle ore 17:27 1520 gis <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Hi developers,
>> I am following the guide in here
>> <http://docs.geonode.org/en/2.10.x/install/core/index.html>.
>> After creating the file /etc/uwsgi/apps-available/geonode.ini
>> and the symbolic link sudo ln -s /etc/uwsgi/apps-available/geonode.ini
>> /etc/uwsgi/apps-enabled/geonode.ini
>> uwsgi service won't start. Any help on that will be very appreciated it.
>> Find the logs bellow on an Ubuntu18.04LTS machine.
>> Fri Jan 24 13:12:48 2020 - *** Starting uWSGI 2.0.15-debian (64bit) on
>> [Fri Jan 24 13:12:48 2020] ***
>> Fri Jan 24 13:12:48 2020 - compiled with version: 7.3.0 on 28 September
>> 2018 15:41:15
>> Fri Jan 24 13:12:48 2020 - os: Linux-5.3.0-26-generic #28~18.04.1-Ubuntu
>> SMP Wed Dec 18 16:40:14 UTC 2019
>> Fri Jan 24 13:12:48 2020 - nodename: 172-21-14-45
>> Fri Jan 24 13:12:48 2020 - machine: x86_64
>> Fri Jan 24 13:12:48 2020 - clock source: unix
>> Fri Jan 24 13:12:48 2020 - pcre jit disabled
>> Fri Jan 24 13:12:48 2020 - detected number of CPU cores: 1
>> Fri Jan 24 13:12:48 2020 - current working directory: /
>> Fri Jan 24 13:12:48 2020 - writing pidfile to /run/uwsgi/app/geonode/pid
>> Fri Jan 24 13:12:48 2020 - detected binary path: /usr/bin/uwsgi-core
>> Fri Jan 24 13:12:48 2020 - dropping root privileges as early as possible
>> Fri Jan 24 13:12:48 2020 - setgid() to 33
>> Fri Jan 24 13:12:48 2020 - set additional group 27 (sudo)
>> Fri Jan 24 13:12:48 2020 - setuid() to 1001
>> Fri Jan 24 13:12:48 2020 - chdir() to /opt/geonode
>> Fri Jan 24 13:12:48 2020 - your processes number limit is 23611
>> Fri Jan 24 13:12:48 2020 - your memory page size is 4096 bytes
>> Fri Jan 24 13:12:48 2020 - *** WARNING: you have enabled harakiri
>> without post buffering. Slow upload could be rejected on post-unbuffered
>> webservers ***
>> Fri Jan 24 13:12:48 2020 - detected max file descriptor number: 1024
>> Fri Jan 24 13:12:48 2020 - lock engine: pthread robust mutexes
>> Fri Jan 24 13:12:48 2020 - thunder lock: enabled
>> Fri Jan 24 13:12:48 2020 - uwsgi socket 0 bound to UNIX address
>> /run/uwsgi/app/geonode/socket fd 3
>> Fri Jan 24 13:12:48 2020 - uwsgi socket 1 bound to TCP address
>> 0.0.0.0:8000 fd 5
>> Fri Jan 24 13:12:48 2020 - dropping root privileges after socket binding
>> Fri Jan 24 13:12:48 2020 - Python version: 2.7.17 (default, Nov 7 2019,
>> 10:07:09) [GCC 7.4.0]
>> Fri Jan 24 13:12:48 2020 - Set PythonHome to
>> ImportError: No module named site
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200124/20969d6b/attachment-0001.html>
More information about the geonode-users
