[GeoNode-users] geonode-users Digest, Vol 60, Issue 12
SILVIA GAMERO
gamerinsky at gmail.com
Fri Jan 24 09:50:43 PST 2020
Thanks for yous emails,
At this moment the server has docker installed on Centos 7.
But, I would like to know if this is the next step.
Deploy a vanilla GeoNode 2.10 with Docker
<http://docs.geonode.org/en/master/install/core/index.html#deploy-a-vanilla-geonode-2-10-with-docker>
Clone the Project
# Let's create the GeoNode core base folder and clone it
sudo mkdir -p /opt/geonode/
sudo usermod -a -G www-data geonode
sudo chown -Rf geonode:www-data /opt/geonode/
sudo chmod -Rf 775 /opt/geonode/
# Clone the GeoNode source code on /opt/geonodecd /opt
git clone https://github.com/GeoNode/geonode.git geonode
kind regards,
On Fri, Jan 24, 2020 at 10:27 AM <geonode-users-request at lists.osgeo.org>
wrote:
> Send geonode-users mailing list submissions to
> geonode-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> geonode-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of geonode-users digest..."
> Today's Topics:
> 1. Re: install geonode 2.10.2 (1520 gis)
> 2. Re: install geonode 2.10.2 (Alessio Fabiani)
> 3. uwsgi service won't start (1520 gis)
> Message: 1
> Date: Fri, 24 Jan 2020 10:32:10 -0300
> From: 1520 gis <juliermeopensourcedeveloper at gmail.com>
> To: SILVIA GAMERO <gamerinsky at gmail.com>
> Cc: geonode-users <geonode-users at lists.osgeo.org>
> Subject: Re: [GeoNode-users] install geonode 2.10.2
> Message-ID:
> CAKTKyJKdyCWSXree4XYGXOZVrqYOoEmATpCA5ToF-dFPo7wDog at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi Silvia,
> I would start with Docker.
> Create a docker Ubuntu18.04 container and expose ports 8000, 8080 and 80
> and I think you are all set:
> docker run -i -t -p 8000:8000 -p 8080:8080 -p 80:80 --name geonode
> ubuntu:18.04 /bin/bash
> I hope it can help
> kind regards
> Julierme
> On Tue, Jan 21, 2020 at 1:26 PM SILVIA GAMERO <gamerinsky at gmail.com>
> wrote:
> > Good morning,
> > I would like some help, I need to install Geonode 2.10.2 on Centos 7.
> > Because the information that I have read is only for Ubuntu,
> > Thanks for your help,
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/geonode-users/attachments/20200124/44b4a522/attachment-0001.html
> Message: 2
> Date: Fri, 24 Jan 2020 14:37:26 +0100
> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> To: 1520 gis <juliermeopensourcedeveloper at gmail.com>
> Cc: SILVIA GAMERO <gamerinsky at gmail.com>, geonode-users
> Message-ID:
> CAM7ZvLJHB6qV3+vHZ1vhoyrQwyRBUgKmiLas0i1mxV0E5DckRA at mail.gmail.com>
> Not an updated guide unfortunately.
> You could try maybe the docker option on Centos by following those steps:
> http://docs.geonode.org/en/master/install/core/index.html#id1
> Il giorno ven 24 gen 2020 alle ore 14:32 1520 gis <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
> > Hi Silvia,
> > I hope it can help
> > kind regards
> > Julierme
> > wrote:
> >> Good morning,
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V
> for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> URL: <
> http://lists.osgeo.org/pipermail/geonode-users/attachments/20200124/651d55e1/attachment-0001.html
> Message: 3
> Date: Fri, 24 Jan 2020 13:27:01 -0300
> To: geonode-devel <geonode-devel at lists.osgeo.org>, geonode-users
> Subject: [GeoNode-users] uwsgi service won't start
> Message-ID:
> CAKTKyJLv0hDD4GZs+x--w9FwvhgZ6gYx7MoTrgNBkL9_ngTMFA at mail.gmail.com>
> Hi developers,
> I am following the guide in here
> <http://docs.geonode.org/en/2.10.x/install/core/index.html>.
> After creating the file /etc/uwsgi/apps-available/geonode.ini
> and the symbolic link sudo ln -s /etc/uwsgi/apps-available/geonode.ini
> /etc/uwsgi/apps-enabled/geonode.ini
> uwsgi service won't start. Any help on that will be very appreciated it.
> Find the logs bellow on an Ubuntu18.04LTS machine.
> Fri Jan 24 13:12:48 2020 - *** Starting uWSGI 2.0.15-debian (64bit) on [Fri
> Jan 24 13:12:48 2020] ***
> Fri Jan 24 13:12:48 2020 - compiled with version: 7.3.0 on 28 September
> 2018 15:41:15
> Fri Jan 24 13:12:48 2020 - os: Linux-5.3.0-26-generic #28~18.04.1-Ubuntu
> SMP Wed Dec 18 16:40:14 UTC 2019
> Fri Jan 24 13:12:48 2020 - nodename: 172-21-14-45
> Fri Jan 24 13:12:48 2020 - machine: x86_64
> Fri Jan 24 13:12:48 2020 - clock source: unix
> Fri Jan 24 13:12:48 2020 - pcre jit disabled
> Fri Jan 24 13:12:48 2020 - detected number of CPU cores: 1
> Fri Jan 24 13:12:48 2020 - current working directory: /
> Fri Jan 24 13:12:48 2020 - writing pidfile to /run/uwsgi/app/geonode/pid
> Fri Jan 24 13:12:48 2020 - detected binary path: /usr/bin/uwsgi-core
> Fri Jan 24 13:12:48 2020 - dropping root privileges as early as possible
> Fri Jan 24 13:12:48 2020 - setgid() to 33
> Fri Jan 24 13:12:48 2020 - set additional group 27 (sudo)
> Fri Jan 24 13:12:48 2020 - setuid() to 1001
> Fri Jan 24 13:12:48 2020 - chdir() to /opt/geonode
> Fri Jan 24 13:12:48 2020 - your processes number limit is 23611
> Fri Jan 24 13:12:48 2020 - your memory page size is 4096 bytes
> Fri Jan 24 13:12:48 2020 - *** WARNING: you have enabled harakiri without
> post buffering. Slow upload could be rejected on post-unbuffered webservers
> Fri Jan 24 13:12:48 2020 - detected max file descriptor number: 1024
> Fri Jan 24 13:12:48 2020 - lock engine: pthread robust mutexes
> Fri Jan 24 13:12:48 2020 - thunder lock: enabled
> Fri Jan 24 13:12:48 2020 - uwsgi socket 0 bound to UNIX address
> /run/uwsgi/app/geonode/socket fd 3
> Fri Jan 24 13:12:48 2020 - uwsgi socket 1 bound to TCP address
> 0.0.0.0:8000
> fd 5
> Fri Jan 24 13:12:48 2020 - dropping root privileges after socket binding
> Fri Jan 24 13:12:48 2020 - Python version: 2.7.17 (default, Nov 7 2019,
> 10:07:09) [GCC 7.4.0]
> Fri Jan 24 13:12:48 2020 - Set PythonHome to
> /home/geonode/.virtualenvs/geonode
> ImportError: No module named site
> URL: <
> http://lists.osgeo.org/pipermail/geonode-users/attachments/20200124/37d3c4c3/attachment.html
> Subject: Digest Footer
> End of geonode-users Digest, Vol 60, Issue 12
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200124/68b972ea/attachment.html>
More information about the geonode-users
