[GeoNode-users] Install from geonode project
Handy Rusydi handy at galerigis.com
Thu Jun 11 16:02:07 PDT 2020
Thanks Alessio,
I have read the instructions. I cant found settings.py at my geonode
project, but I can find the settings.py at the
~/.virtualenvs/project_name/src/geonode/geonode
I have no idea how cant this happen. Any suggestions?
Other people are also welcome to give me some suggestion
Pada tanggal Kam, 11 Jun 2020 pukul 14.43 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> menulis:
> Hi Handy,
> please, follow the instructions *carefully *here
> https://docs.geonode.org/en/master/install/basic/index.html
> Regards,
> Alessio.
> Il giorno gio 11 giu 2020 alle ore 02:23 Handy Rusydi <handy at galerigis.com>
> ha scritto:
>> Hai,
>> I am trying to install geonode from geonode project here
>> https://github.com/GeoNode/geonode-project
>> I am using master branch. When I run paver start, it said that connection
>> refused.
>> I have to edit .env files, with my vps IP address, but no luck, there is
>> still refused my connection. I have double check that, there is no
>> localhost settin anymore in there.
>> I hope someone can help me for this situation.
>> Thank you
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200612/24fd7c45/attachment.html>
More information about the geonode-users mailing list
