[GeoNode-users] Install from geonode project
Rizky Maulana Nugraha rizky at kartoza.com
Tue Jun 16 09:34:39 PDT 2020
Hi Handy,
> I have read the instructions. I cant found settings.py at my geonode project, but I can find the settings.py at the ~/.virtualenvs/project_name/src/geonode/geonode
I find it odd that the location of the apps is inside ~/.virtualenvs . Have you been following this documentation: https://docs.geonode.org/en/master/install/advanced/project/index.html ?
The settings file should in the directory of where your geonode project is. The folder is renamed into whatever project_name you choose at the beginning when you run "django-admin startproject ..."
If you do it correctly, there should be two folder in your working directory. In above example, the working directory is “/opt/geonode_custom”, there will folder “/opt/geonode_custom/geonode-project” and “/opt/geonode_custom/my_geonode”. Then the settings file you need to change is in the “/opt/geonode_custom/my_geonode”.
Regards,
Senior Software Engineer
Kartoza
On 12 Jun 2020 06.02 +0700, Handy Rusydi <handy at galerigis.com>, wrote:
> Thanks Alessio,
> I have no idea how cant this happen. Any suggestions?
> Other people are also welcome to give me some suggestion
> > Pada tanggal Kam, 11 Jun 2020 pukul 14.43 Alessio Fabiani <alessio.fabiani at geo-solutions.it> menulis:
> > > Hi Handy,
> > > please, follow the instructions carefully here
> > > https://docs.geonode.org/en/master/install/basic/index.html
> > > Regards,
> > > Alessio.
> > > > Il giorno gio 11 giu 2020 alle ore 02:23 Handy Rusydi <handy at galerigis.com> ha scritto:
> > > > > Hai,
> > > > > I am trying to install geonode from geonode project here
> > > > > https://github.com/GeoNode/geonode-project
> > > > > I am using master branch. When I run paver start, it said that connection refused.
> > > > > I have to edit .env files, with my vps IP address, but no luck, there is still refused my connection. I have double check that, there is no localhost settin anymore in there.
> > > > > I hope someone can help me for this situation.
> > > > > Thank you
> > > > > _______________________________________________
> > > > > geonode-users mailing list
> > > > > geonode-users at lists.osgeo.org
> > > > > https://lists.osgeo.org/mailman/listinfo/geonode-users
> > > GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
> > > Ing. Alessio Fabiani
> > > @alfa7691
> > > Founder/Technical Lead
> > > GeoSolutions S.A.S.
> > > Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> > > phone: +39 0584 962313
> > > fax:     +39 0584 1660272
> > > mob:   +39 331 6233686
> > > http://www.geo-solutions.it
> > > http://twitter.com/geosolutions_it
> > > Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> > > This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200616/8918398e/attachment.html>
More information about the geonode-users mailing list
