[GeoNode-users] Issues with mosaics in GeoNode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Jun 15 09:18:48 PDT 2020
Uhm, it is worth to double check then.
Il giorno lun 15 giu 2020 alle ore 18:08 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Ciao Alessio,
> Thanks for your help. I've solved the issue. Probably I've messed up gdal
> (a long story...). WIth a fresh installation everything is fine. Anyway,
> I've used the datastore.properties file as suggested and it works
> pretty well.
> About the cache. I believe the _invalidate_geowebcache_layer method is
> called not only when the style is updated (which is fine) but probably
> every time the metadata is updated (which can cause some headache if you
> work with large datasets).
> Paolo
> On Wed, May 20, 2020 at 9:59 AM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hi Paolo,
>> so you are using GeoNode 2.10.3 and GeoServer 2.15.4 I guess, is that
>> correct?
>> First of all, as soon as possible update GeoServer with the same version
>> WAR here
>> <https://build.geo-solutions.it/geonode/geoserver/latest/geoserver-2.15.4.war>,
>> The WARs have been rebuilt recently with some updates of GeoServer
>> community plugins.
>> Secondly, are you trying to create the mosaic by using the shapefile
>> index? Try to create the "datastore.properties" and let GeoServer create
>> the index on the DB instead.
>> I recently configured a mosaic with more than 120K granules and it worked
>> seamlessly.
>> A warning here. When you create the store, the first time, GeoServer will
>> remain blocked for a long time, until he finished scanning all the
>> granules. Even if you have some strange page back on the gui or some odd
>> behavior, don't worry about it.
>> Finally, there's a method on GeoNode "_invalidate_geowebcache_layer"
>> which is called when you create a Layer and mostly when you update the
>> style.
>> Currently, the behavior is trivial, he just invokes the method every time
>> you update the style. It probably could be improved.
>> Il giorno ven 15 mag 2020 alle ore 16:56 Paolo Pasquali <
>>> Dear all,
>>> I'm trying to publish two mosaics of about 3500 tiles each in GeoNode.
>>> Firstly, I've created the shp index and the tile cache on a stand alone
>>> GeoServer installation without any problem.
>>> Then I've moved the mosaic tiles and all the cache on a GeoNode 2.10.3
>>> that I've installed following this documentation:
>>> https://docs.geonode.org/en/2.10/install/core/index.html#ubuntu-18-04
>>> 1) The first issue I have encountered is that for both mosaics I get a
>>> "Too many open files" error from GeoServer. I've both tried to use the old
>>> shp index and to generate a new one with the GeoNode GeoServer but I always
>>> get this error.
>>> I've also disabled the JAI ImageRead (deferred loading) but nothing
>>> improved.
>>> I'm wondering why there is a different behaviour between the two
>>> GeoServers. Maybe I've messed up some gdal library? The gdal version is
>>> 2.2.3 on Ubuntu 18.04
>>> 2) The second issue is the Metadata update via GeoNode. I've used
>>> updatelayers to import the mosaics in GeoNode and then I have used the
>>> wizard to update the metadata. By updating the metadata, all the tile cache
>>> has been flushed. Is this the expected behaviour? I understand for small
>>> rasters may be convenient but in other cases it may not. Is there a way to
>>> set whether the wizard can flush the cache when updating the metadata?
>>> Thanks in advance for your help.
>>> Best,
>>> Paolo
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200615/30b04fdf/attachment-0001.html>
More information about the geonode-users
