[GeoNode-users] error install ubuntu 18.04
Muhammad Iqbal Firdaus
muh.firdausiqbal at gmail.com
Wed Jun 17 20:56:15 PDT 2020
Dear Geonode masters,
I'm new at geonode installation and encourage to dive and understand
geonode usage and development, however when i try to install geonode i get
the following error message, when installing the shell script based on the
installation documentation (Geonode Basic) for geonode 3. Here is the error:
E: Failed to fetch http://deb.debian.org/debian/pool/main/a/armadillo/li
barmadillo9_9.200.7+dfsg-1_amd64.deb Connection failed [IP:
151.101.8.2
04 80]
E: Failed to fetch http://deb.debian.org/debian/pool/main/b/boost1.67/li
bboost1.67-dev_1.67.0-13+deb10u1_amd64.deb Connection failed
[IP: 151.1
01.8.204 80]
E: Failed to fetch http://deb.debian.org/debian/pool/main/c/charls/libch
arls-dev_2.0.0+dfsg-1_amd64.deb Connection failed [IP:
151.101.8.204 80
E: Failed to fetch http://deb.debian.org/debian/pool/main/j/json-c/libjs
on-c3_0.12.1+ds-2_amd64.deb Connection failed [IP: 151.101.8.204
80]
E: Failed to fetch http://deb.debian.org/debian/pool/main/o/ogdi-dfsg/li
bogdi3.2_3.2.1+ds-4_amd64.deb Connection failed [IP:
151.101.8.204 80]
bogdi3.2-dev_3.2.1+ds-4_amd64.deb Connection failed [IP:
151.101.8.204
80]
E: Failed to fetch http://deb.debian.org/debian/pool/main/libm/libmemcac
hed/libhashkit2_1.0.18-4.2_amd64.deb Connection failed [IP:
151.101.8.2
04 80]
E: Failed to fetch http://apt.postgresql.org/pub/repos/apt/pool/main/p/p
ostgresql-common/postgresql-client-common_215.pgdg100+1_all.deb
Connect
ion failed [IP: 217.196.149.55 80]
E: Unable to fetch some archives, maybe run apt-get update or try with -
-fix-missing?
ERROR: Service 'django' failed to build: The command '/bin/sh -c apt-get
update && apt-get install -y gcc zip
g
ettext postgresql-client-11 libpq-dev
sqlite3 spatiali
te-bin libsqlite3-mod-spatialite
python3-gdal python3-ps
ycopg2 python3-ldap
python3-pil python3-lxml python3-pyl
ibmc
python3-dev libgdal-dev libxml2 lib
xml2-dev
libxslt1-dev zlib1g-dev libjpeg-dev libmemcache
d-dev libsasl2-dev libldap2-dev libsasl2-dev
uwsgi uwsgi-plugin-python3 --no-install-recommends
&& rm -r
f /var/lib/apt/lists/*' returned a non-zero code: 100
WARNING! This will remove:
- all stopped containers
- all networks not used by at least one container
- all images without at least one container associated to them
- all build cache
Are you sure you want to continue? [y/N]
if i type y then the installation is aborted and canceled, i suspect that
the error is because the file packag is not found. Do you know how to
figure out to fix this?
do i have to check the advance installation, and do one by one installation
based on script,?
Thanks in advance
Regards,
Iqbal
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200618/d6f9048c/attachment.html>
More information about the geonode-users
