[GeoNode-users] error install ubuntu 18.04
    Rizky Maulana Nugraha
    rizky at kartoza.com
    Thu Jun 18 07:42:45 PDT 2020
Hi Iqbal,
Can you tell me which installation instruction you use?
At a glance, it seems the error is not related with GeoNode. Maybe something to do with the network.
Since the log mentions images. It seems you are trying to build docker images.
Make sure your docker network are able to reach the internet.
Regards,
Senior Software Engineer
Kartoza
On 18 Jun 2020 10.56 +0700, Muhammad Iqbal Firdaus , wrote:
> Dear Geonode masters,
> I'm new at geonode installation and encourage to dive and understand geonode usage and development, however when i try to install geonode i get the following error message, when installing the shell script based on the installation documentation (Geonode Basic) for geonode 3. Here is the error:
> E: Failed to fetch http://deb.debian.org/debian/pool/main/a/armadillo/li        barmadillo9_9.200.7+dfsg-1_amd64.deb  Connection failed [IP: 151.101.8.2        04 80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/b/boost1.67/li        bboost1.67-dev_1.67.0-13+deb10u1_amd64.deb  Connection failed [IP: 151.1        01.8.204 80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/c/charls/libch        arls-dev_2.0.0+dfsg-1_amd64.deb  Connection failed [IP: 151.101.8.204 80        ]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/j/json-c/libjs        on-c3_0.12.1+ds-2_amd64.deb  Connection failed [IP: 151.101.8.204 80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/o/ogdi-dfsg/li        bogdi3.2_3.2.1+ds-4_amd64.deb  Connection failed [IP: 151.101.8.204 80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/o/ogdi-dfsg/li        bogdi3.2-dev_3.2.1+ds-4_amd64.deb  Connection failed [IP: 151.101.8.204        80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/libm/libmemcac        hed/libhashkit2_1.0.18-4.2_amd64.deb  Connection failed [IP: 151.101.8.2        04 80]
> E: Failed to fetch http://apt.postgresql.org/pub/repos/apt/pool/main/p/p        ostgresql-common/postgresql-client-common_215.pgdg100+1_all.deb  Connect        ion failed [IP: 217.196.149.55 80]
> E: Unable to fetch some archives, maybe run apt-get update or try with -        -fix-missing?
> ERROR: Service 'django' failed to build: The command '/bin/sh -c apt-get        update && apt-get install -y           gcc                 zip        g        ettext          postgresql-client-11 libpq-dev          sqlite3 spatiali        te-bin libsqlite3-mod-spatialite                 python3-gdal python3-ps        ycopg2 python3-ldap                 python3-pil python3-lxml python3-pyl        ibmc                 python3-dev libgdal-dev                 libxml2 lib        xml2-dev libxslt1-dev zlib1g-dev libjpeg-dev                 libmemcache        d-dev libsasl2-dev                 libldap2-dev libsasl2-dev        uwsgi uwsgi-plugin-python3         --no-install-recommends && rm -r        f /var/lib/apt/lists/*' returned a non-zero code: 100
> WARNING! This will remove:
>   - all stopped containers
>   - all networks not used by at least one container
>   - all images without at least one container associated to them
>   - all build cache
> Are you sure you want to continue? [y/N]
> if i type y then the installation is aborted and canceled, i suspect that the error is because the file packag is not found. Do you know how to figure out to fix this?
> do i have to check the advance installation, and do one by one installation based on script,?
> Thanks in advance
> Regards,
> Iqbal
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200618/de64007d/attachment-0001.html>
More information about the geonode-users
