[GeoNode-users] error install ubuntu 18.04
Muhammad Iqbal Firdaus muh.firdausiqbal at gmail.com
Sun Jun 21 01:40:16 PDT 2020
Hello,
Apologize, maybe this email finds as duplicate post for previous thread
from my question about installation geonode in Ubuntu. I would just to let
you know, that the installation of geonode docker-build.sh in my device is
encountered error due to network from ISP (i believe). the result i get i
compare between Ubuntu Linux Desktop (Failed install) and Server
(Successfully installed) previously, using different laptop. The one that
success is using VPN, while the failed one is not using VPN. I just
realized, when i also trying to install docker-build.sh (geonode) in ubuntu
server, without VPN is encountered error persists with the previously
installing in ubuntu desktop. Hence, i think the problem is with the
network with VPN is more secure and importantly uninterrupted installation
process when getting the archive from ubuntu server.
Here it is the installation process when using VPN, sucessfully installed i
guest.
[image: image.png]
Regards
Iqbal
On Thu, Jun 18, 2020 at 10:56 AM Muhammad Iqbal Firdaus <
muh.firdausiqbal at gmail.com> wrote:
> Dear Geonode masters,
> I'm new at geonode installation and encourage to dive and understand
> geonode usage and development, however when i try to install geonode i get
> the following error message, when installing the shell script based on the
> installation documentation (Geonode Basic) for geonode 3. Here is the error:
> E: Failed to fetch http://deb.debian.org/debian/pool/main/a/armadillo/li
>             barmadillo9_9.200.7+dfsg-1_amd64.deb  Connection failed [IP:
> 151.101.8.2
>                         04 80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/b/boost1.67/li
>             bboost1.67-dev_1.67.0-13+deb10u1_amd64.deb  Connection failed
> [IP: 151.1
>                         01.8.204 80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/c/charls/libch
>             arls-dev_2.0.0+dfsg-1_amd64.deb  Connection failed [IP:
> 151.101.8.204 80
> E: Failed to fetch http://deb.debian.org/debian/pool/main/j/json-c/libjs
>             on-c3_0.12.1+ds-2_amd64.deb  Connection failed [IP:
> 151.101.8.204 80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/o/ogdi-dfsg/li
>             bogdi3.2_3.2.1+ds-4_amd64.deb  Connection failed [IP:
> 151.101.8.204 80]
>             bogdi3.2-dev_3.2.1+ds-4_amd64.deb  Connection failed [IP:
> 151.101.8.204
>                            80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/libm/libmemcac
>             hed/libhashkit2_1.0.18-4.2_amd64.deb  Connection failed [IP:
> 151.101.8.2
>                         04 80]
> E: Failed to fetch http://apt.postgresql.org/pub/repos/apt/pool/main/p/p
>             ostgresql-common/postgresql-client-common_215.pgdg100+1_all.deb
>  Connect
>                       ion failed [IP: 217.196.149.55 80]
> E: Unable to fetch some archives, maybe run apt-get update or try with -
>           -fix-missing?
> ERROR: Service 'django' failed to build: The command '/bin/sh -c apt-get
>            update && apt-get install -y           gcc                 zip
>      g
>                     ettext          postgresql-client-11 libpq-dev
>  sqlite3 spatiali
>                               te-bin libsqlite3-mod-spatialite
>     python3-gdal python3-ps
>                                         ycopg2 python3-ldap
> python3-pil python3-lxml python3-pyl
>                                                   ibmc
> python3-dev libgdal-dev                 libxml2 lib
>        xml2-dev
> libxslt1-dev zlib1g-dev libjpeg-dev                 libmemcache
> d-dev libsasl2-dev                 libldap2-dev libsasl2-dev
>                uwsgi uwsgi-plugin-python3         --no-install-recommends
> && rm -r
>                         f /var/lib/apt/lists/*' returned a non-zero code:
> 100
> WARNING! This will remove:
>   - all stopped containers
>   - all networks not used by at least one container
>   - all images without at least one container associated to them
>   - all build cache
> Are you sure you want to continue? [y/N]
> if i type y then the installation is aborted and canceled, i suspect that
> the error is because the file packag is not found. Do you know how to
> figure out to fix this?
> do i have to check the advance installation, and do one by one
> installation based on script,?
> Thanks in advance
> Regards,
> Iqbal
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200621/85935105/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200621/85935105/attachment-0001.png>
More information about the geonode-users mailing list
