[GeoNode-users] error install ubuntu 18.04
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Jun 18 08:30:14 PDT 2020
Dear Muhammad,
not sure how/where/when you get those log errors, can you explain the
passages you have done?
1) Are those steps went all well
https://docs.geonode.org/en/master/install/basic/index.html#packages-installation
2) Did you successfully installed Docker and docker-compose?
https://docs.geonode.org/en/master/install/basic/index.html#docker-setup-first-time-only
3) Have you successfully created an instance of geonode-peoject with
another name?
https://docs.geonode.org/en/master/install/basic/index.html#create-an-instance-of-your-geonode-project
Il giorno gio 18 giu 2020 alle ore 17:12 Muhammad Iqbal Firdaus <
muh.firdausiqbal at gmail.com> ha scritto:
> Hello,
> I try the installation for basic install from geonode 3 documentation. I
> have tried like several times, unfortunately get the similar error. I tried
> also to change the server to singapore but no luck. Anyway, similar error
> always happens with those files. I suspect maybe the error because there is
> no package in server maybe. Or do you know the reason why?
> Regards,
> Iqbal
> On Thu, Jun 18, 2020, 9:43 PM Rizky Maulana Nugraha <rizky at kartoza.com>
> wrote:
>> Hi Iqbal,
>> Can you tell me which installation instruction you use?
>> At a glance, it seems the error is not related with GeoNode. Maybe
>> something to do with the network.
>> Since the log mentions images. It seems you are trying to build docker
>> images.
>> Make sure your docker network are able to reach the internet.
>> Regards,
>> Senior Software Engineer
>> Kartoza
>> On 18 Jun 2020 10.56 +0700, Muhammad Iqbal Firdaus , wrote:
>> Dear Geonode masters,
>> I'm new at geonode installation and encourage to dive and understand
>> geonode usage and development, however when i try to install geonode i get
>> the following error message, when installing the shell script based on the
>> installation documentation (Geonode Basic) for geonode 3. Here is the error:
>> E: Failed to fetch http://deb.debian.org/debian/pool/main/a/armadillo/li
>> barmadillo9_9.200.7+dfsg-1_amd64.deb Connection failed [IP:
>> 151.101.8.2
>> 04 80]
>> E: Failed to fetch http://deb.debian.org/debian/pool/main/b/boost1.67/li
>> bboost1.67-dev_1.67.0-13+deb10u1_amd64.deb Connection failed
>> [IP: 151.1
>> 01.8.204 80]
>> E: Failed to fetch http://deb.debian.org/debian/pool/main/c/charls/libch
>> arls-dev_2.0.0+dfsg-1_amd64.deb Connection failed [IP:
>> 151.101.8.204 80
>> E: Failed to fetch http://deb.debian.org/debian/pool/main/j/json-c/libjs
>> on-c3_0.12.1+ds-2_amd64.deb Connection failed [IP:
>> 151.101.8.204 80]
>> E: Failed to fetch http://deb.debian.org/debian/pool/main/o/ogdi-dfsg/li
>> bogdi3.2_3.2.1+ds-4_amd64.deb Connection failed [IP:
>> 151.101.8.204 80]
>> bogdi3.2-dev_3.2.1+ds-4_amd64.deb Connection failed [IP:
>> 151.101.8.204
>> 80]
>> E: Failed to fetch http://deb.debian.org/debian/pool/main/libm/libmemcac
>> hed/libhashkit2_1.0.18-4.2_amd64.deb Connection failed [IP:
>> 151.101.8.2
>> 04 80]
>> E: Failed to fetch http://apt.postgresql.org/pub/repos/apt/pool/main/p/p
>> ostgresql-common/postgresql-client-common_215.pgdg100+1_all.deb
>> Connect
>> ion failed [IP: 217.196.149.55 80]
>> E: Unable to fetch some archives, maybe run apt-get update or try with -
>> -fix-missing?
>> ERROR: Service 'django' failed to build: The command '/bin/sh -c apt-get
>> update && apt-get install -y gcc zip
>> g
>> ettext postgresql-client-11 libpq-dev
>> sqlite3 spatiali
>> te-bin libsqlite3-mod-spatialite
>> python3-gdal python3-ps
>> ycopg2 python3-ldap
>> python3-pil python3-lxml python3-pyl
>> ibmc
>> python3-dev libgdal-dev libxml2 lib
>> xml2-dev
>> libxslt1-dev zlib1g-dev libjpeg-dev libmemcache
>> d-dev libsasl2-dev libldap2-dev libsasl2-dev
>> uwsgi uwsgi-plugin-python3 --no-install-recommends
>> && rm -r
>> f /var/lib/apt/lists/*' returned a non-zero code:
>> 100
>> WARNING! This will remove:
>> - all stopped containers
>> - all networks not used by at least one container
>> - all images without at least one container associated to them
>> - all build cache
>> Are you sure you want to continue? [y/N]
>> if i type y then the installation is aborted and canceled, i suspect that
>> the error is because the file packag is not found. Do you know how to
>> figure out to fix this?
>> do i have to check the advance installation, and do one by one
>> installation based on script,?
>> Thanks in advance
>> Regards,
>> Iqbal
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200618/dae38985/attachment-0001.html>
More information about the geonode-users
