[GeoNode-users] updatelayers "httplib2.socks.HTTPError: (403, 'Forbidden')" problem
Giuliano Grigolin
giuliano.geobases at gmail.com
Fri Mar 20 06:43:13 PDT 2020
no changes ...
root at geonode:/usr/lib/python2.7/dist-packages/django/conf/project_template#
DJANGO_SETTINGS_MODULE=geonode.local_settings python manage.py updatelayers
-w geonode
Inspecting the available layers in GeoServer ...
GET http://localhost:8080/geoserver/rest/workspaces.xml
File "manage.py", line 11, in <module>
execute_from_command_line(sys.argv)
File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
354, in execute_from_command_line
utility.execute()
File
346, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 394, in run_from_argv
self.execute(*args, **cmd_options)
line 445, in execute
output = self.handle(*args, **options)
File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/updatelayers.py",
line 122, in handle
execute_signals=True)
File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
531, in gs_slurp
workspace = cat.get_workspace(workspace)
File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 1031,
in get_workspace
workspaces = self.get_workspaces(name)
File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 1011,
in get_workspaces
description = self.get_xml("%s/workspaces.xml" % self.service_url)
File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 211,
in get_xml
response, content = self.http.request(rest_url)
File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1659,
in request
(response, content) = self._request(conn, authority, uri, request_uri,
method, body, headers, redirections, cachekey)
File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1399,
in _request
(response, content) = self._conn_request(conn, request_uri, method,
body, headers)
File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1319,
in _conn_request
conn.connect()
File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 946,
in connect
self.sock.connect((self.host, self.port) + sa[2:])
File "/usr/lib/python2.7/dist-packages/httplib2/socks.py", line 434, in
connect
self.__negotiatehttp(destpair[0], destpair[1])
File "/usr/lib/python2.7/dist-packages/httplib2/socks.py", line 400, in
__negotiatehttp
raise HTTPError((statuscode, statusline[2]))
On Fri, Mar 20, 2020 at 3:41 AM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Hi Giuliano,
> in addition to Giovanni. Remember that you also can define the settings
> file:
> For example:
> DJANGO_SETTINGS_MODULE=your_geonode.local_settings python manage.py ...
> Depending on your environment be sure to use the correct one.
> Cheers
> Toni
> Am 19.03.2020 um 22:29 schrieb geonode-users-request at lists.osgeo.org:
> *Von: *"G. Allegri" <giovanni.allegri at geo-solutions.it>
> *Betreff: **Aw: [GeoNode-users] updatelayers "httplib2.socks.HTTPError:
> (403, 'Forbidden')" problem ...*
> *Datum: *19. März 2020 um 22:04:45 MEZ
> *An: *Giuliano Grigolin <giuliano.geobases at gmail.com>
> *Kopie: *geonode-users <geonode-users at lists.osgeo.org>
> Are you sure Geoserver credentials (admin user and password) are
> configured correctly on GeoNode?
> Giovanni
> Il gio 19 mar 2020, 21:37 Giuliano Grigolin <giuliano.geobases at gmail.com>
> ha scritto:
>> Hi all !
>> I have a GeoNode 2.8 in production, with internet domain, in Ubuntu
>> Server 16.04.
>> When i try update a layer that i import trough "Import Data" in
>> GeoServer, i get the following message:
>> root at geonode# python manage.py updatelayers -w geonode -f
>> my_layer_in_GeoServer
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200320/1ce9e77b/attachment-0001.html>
More information about the geonode-users
