[GeoNode-users] updatelayers "httplib2.socks.HTTPError: (403, 'Forbidden')" problem
G. Allegri giovanni.allegri at geo-solutions.it
Fri Mar 20 06:54:05 PDT 2020
How did you setup Geoserver?
And a basic question: are you able to see any map inside GeoNode? I mean,
is Geoserver responding outside of the updatelayers command?
Il ven 20 mar 2020, 14:47 Giuliano Grigolin <giuliano.geobases at gmail.com>
ha scritto:
> no changes ...
> root at geonode:/usr/lib/python2.7/dist-packages/django/conf/project_template#
> DJANGO_SETTINGS_MODULE=geonode.local_settings python manage.py updatelayers
> -w geonode
> Inspecting the available layers in GeoServer ...
> GET http://localhost:8080/geoserver/rest/workspaces.xml
> Traceback (most recent call last):
>   File "manage.py", line 11, in <module>
>     execute_from_command_line(sys.argv)
>   File
> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
> 354, in execute_from_command_line
>     utility.execute()
>   File
> 346, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
> line 394, in run_from_argv
>     self.execute(*args, **cmd_options)
> line 445, in execute
>     output = self.handle(*args, **options)
>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/updatelayers.py",
> line 122, in handle
>     execute_signals=True)
>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
> 531, in gs_slurp
>     workspace = cat.get_workspace(workspace)
>   File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 1031,
> in get_workspace
>     workspaces = self.get_workspaces(name)
>   File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 1011,
> in get_workspaces
>     description = self.get_xml("%s/workspaces.xml" % self.service_url)
>   File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 211,
> in get_xml
>     response, content = self.http.request(rest_url)
>   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1659,
> in request
>     (response, content) = self._request(conn, authority, uri, request_uri,
> method, body, headers, redirections, cachekey)
>   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1399,
> in _request
>     (response, content) = self._conn_request(conn, request_uri, method,
> body, headers)
>   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1319,
> in _conn_request
>     conn.connect()
>   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 946,
> in connect
>     self.sock.connect((self.host, self.port) + sa[2:])
>   File "/usr/lib/python2.7/dist-packages/httplib2/socks.py", line 434, in
> connect
>     self.__negotiatehttp(destpair[0], destpair[1])
>   File "/usr/lib/python2.7/dist-packages/httplib2/socks.py", line 400, in
> __negotiatehttp
>     raise HTTPError((statuscode, statusline[2]))
> On Fri, Mar 20, 2020 at 3:41 AM Toni Schönbuchner <
> toni.schoenbuchner at csgis.de> wrote:
>> Hi Giuliano,
>> in addition to Giovanni. Remember that you also can define the settings
>> file:
>> For example:
>> DJANGO_SETTINGS_MODULE=your_geonode.local_settings python manage.py  ...
>> Depending on your environment be sure to use the correct one.
>> Cheers
>> Toni
>> Am 19.03.2020 um 22:29 schrieb geonode-users-request at lists.osgeo.org:
>> *Von: *"G. Allegri" <giovanni.allegri at geo-solutions.it>
>> *Betreff: **Aw: [GeoNode-users] updatelayers "httplib2.socks.HTTPError:
>> (403, 'Forbidden')" problem ...*
>> *Datum: *19. März 2020 um 22:04:45 MEZ
>> *An: *Giuliano Grigolin <giuliano.geobases at gmail.com>
>> *Kopie: *geonode-users <geonode-users at lists.osgeo.org>
>> Are you sure Geoserver credentials (admin user and password) are
>> configured correctly on GeoNode?
>> Giovanni
>> Il gio 19 mar 2020, 21:37 Giuliano Grigolin <giuliano.geobases at gmail.com>
>> ha scritto:
>>> Hi all !
>>> I have a GeoNode 2.8 in production, with internet domain, in Ubuntu
>>> Server 16.04.
>>> When i try update a layer that i import trough "Import Data" in
>>> GeoServer, i get the following message:
>>> root at geonode# python manage.py updatelayers -w geonode -f
>>> my_layer_in_GeoServer
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200320/3451922d/attachment.html>
More information about the geonode-users mailing list
