[GeoNode-users] geonode-users Digest, Vol 69, Issue 5
Davide Marchi danjde at msw.it
Tue Oct 13 03:36:24 PDT 2020
Il 2020-10-13 11:33 geonode-users-request at lists.osgeo.org ha scritto:
> Send geonode-users mailing list submissions to
> 	geonode-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.osgeo.org/mailman/listinfo/geonode-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	geonode-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of geonode-users digest..."
> Today's Topics:
>    1. Re: Geonode installation: Tomcat version (Davide Marchi)
>    2. Re: Geonode installation: Tomcat version (Matthieu Schneider)
>    3. GeoServer Error - HTTP Status 404 – Not Found
>       (Gianluca Zanatta - ABACO S.p.A.)
> Message: 1
> Date: Tue, 13 Oct 2020 10:38:22 +0200
> From: Davide Marchi <danjde at msw.it>
> To: geonode-users at lists.osgeo.org
> Subject: Re: [GeoNode-users] Geonode installation: Tomcat version
> Message-ID: <06f9297f29d99db8eb7a3b84bd85d72f at msw.it>
> Content-Type: text/plain; charset=US-ASCII; format=flowed
> Il 2020-10-12 21:00 Matthieu Schneider <matthieu.schneider at gulfsat.mg>
> ha scritto:
>> Hello Davide, Toni,
>> Thank you for your help ;)
>> Yes, I use both:
>> * docs.geonode.org/en/3.0/install/advanced
>> * docs.geonode.org/en/master/install/advanced
>> just in case there is some difference, but it look like the same page.
>> Yes, the last archive for the Tomcat 8.5 is this one:
>> apache-tomcat-8.5.58.tar.gz, but I will try le 9 version (from deb
>> pkg),
>> I also install java/jdk 11 directly from deb/buster. If I failed, I
>> will
>> give you some news here (and fall-back on 8.5.xx version).
>> My bad for Nginx, I read the doc by blocks, and yes, Nginx is use
>> after.
>> Thank you,
>> Best regards,
>> Matthieu Schneider
>> Madagascar
> Hi Matthieu!
> I don't know for what intended use you are implementing Geonode,
> but if it is for production environment I suggest you to switch to
> Docker installation.
> The "advanced" installation, is missing of many important steps, that
> will not allow you to put the environment into production mode.
> I myself have followed your same path, I have dedicated whole days to
> the project and now I have to abandon to switch to the docker version.
> I've try, Tomcat 9 DEB, and Open Java environment "11.x" and all was
> working fine, but when you must secure the environment everything
> collapses.
> My dispassionate advice is that if you have a lot of time to spend and
> you like to play trying, otherwise give up immediately!!
> Davide
> Italy
> Message: 2
> Date: Tue, 13 Oct 2020 11:49:54 +0300
> From: Matthieu Schneider <matthieu.schneider at gulfsat.mg>
> To: Davide Marchi <danjde at msw.it>, geonode-users at lists.osgeo.org
> Message-ID: <db353b11-e79b-e461-1624-a5e34e31e699 at gulfsat.mg>
> Content-Type: text/plain; charset="utf-8"
>> collapses.
> Hello Davide,
> Thanks for the advice, if important steps are missing, it will be
> difficult, obviously... I will try (because I'm in the config file
> currently), but I keep in mind your advice and probably will change my
> mind after.
> Best regards,
> Matthieu Schneider
> Madagascar
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Type: application/pgp-signature
> Desc: OpenPGP digital signature
> URL:
> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201013/505c4b74/attachment-0001.sig>
> Message: 3
> Date: Tue, 13 Oct 2020 09:33:17 +0000
> From: Gianluca Zanatta - ABACO S.p.A. <gianluca.zanatta at abacospa.it>
> To: geonode-users <geonode-users at lists.osgeo.org>
> Subject: [GeoNode-users] GeoServer Error - HTTP Status 404 – Not
> 	Found
> Message-ID:
> 	<AM7PR07MB634316D0D61D0F9ADD88962F84040 at AM7PR07MB6343.eurprd07.prod.outlook.com>
> Content-Type: text/plain; charset="windows-1252"
> Hello all,
> currently i'm using GeoNode 2.10.1 with GeoServer
> Opening GeoServer from Geonode appears the following message:
> [cid:image003.jpg at 01D6A154.A4C02930]
> Anyone can help me?
> Thank you for your help,
> Best regards,
> Gianluca
> An HTML attachment was scrubbed...
> URL:
> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201013/19045478/attachment.html>
> Type: image/jpeg
> Desc: image003.jpg
> URL:
> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201013/19045478/attachment.jpg>
> Subject: Digest Footer
> End of geonode-users Digest, Vol 69, Issue 5
More information about the geonode-users mailing list
