[GeoNode-users] GeoServer Error - HTTP Status 404 =?utf-8?Q?=E2=80=93_?=Not Found
Francesco Bartoli xbartolone at gmail.com
Tue Oct 13 06:18:31 PDT 2020
From the screenshot that you sent me privately it looks like that GeoServer is not down but is failing to start properly. Unfortunately, the result is quite the same :).
However, I have encountered the same issue (Ref.: https://osgeo-org.atlassian.net/browse/GEOS-9702) in another production instance and the solution was quite straightforward: downgrade the java used by Tomcat to a safe version <1.8.0_254.
It’s likely the binary has been updated recently since the problem appears on version 1.8.0_255 and above as reported in the issue tracker.
Hope this helps
Francesco
Il 13 ott 2020, 15:00 +0200, Amedeo Fadini <amefad at gmail.com>, ha scritto:
> Hi Gianluca,
> As I remember  you're using a barebone installation and not a docker one am I right?
> Can you see the maps? If yes Geoserver is not down
> Check if these urls are working:
> <youserver.domain>/geoserver/web/
> <youserver.domain>/geoserver/index.html
> If you're using apache as a web server check also the (apache.conf) for the proxy directive
> Amefad
> > Il giorno mar 13 ott 2020 alle ore 11:33 Gianluca Zanatta - ABACO S.p.A. <gianluca.zanatta at abacospa.it> ha scritto:
> > > Hello all,
> > > currently i'm using GeoNode 2.10.1 with GeoServer
> > > Opening GeoServer from Geonode appears the following message:
> > > <image003.jpg>
> > > Anyone can help me?
> > > Thank you for your help,
> > > Best regards,
> > > Gianluca
> > > _______________________________________________
> > > geonode-users mailing list
> > > geonode-users at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201013/08a29a91/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201013/08a29a91/attachment-0001.png>
More information about the geonode-users mailing list
