[GeoNode-users] Geonode installation: Tomcat version
Davide Marchi
danjde at msw.it
Tue Oct 13 03:39:06 PDT 2020
Matthieu Schneider ha scritto:
> Le 13/10/2020 à 11:38, Davide Marchi a écrit :
>> I've try, Tomcat 9 DEB, and Open Java environment "11.x" and all was
>> working fine, but when you must secure the environment everything
>> collapses.
>> My dispassionate advice is that if you have a lot of time to spend and
>> you like to play trying, otherwise give up immediately!!
> Hello Davide,
> Thanks for the advice, if important steps are missing, it will be
> difficult, obviously... I will try (because I'm in the config file
> currently), but I keep in mind your advice and probably will change my
> mind after.
> Best regards,
I suggest you to compare both the part of the documentation concerning
the production, you will notice that in the chapter of the advanced
installation it is completely absent.
Ciao!
Davide
More information about the geonode-users
