[GeoNode-users] Timeline (time series data) not working properly in GeoNode 3.0
Adrian Bajer bajeradr at gmail.com
Mon Apr 19 01:46:10 PDT 2021
I'm sending sample data.
GeoServer has time dimension "on" for this layer (see print screen -
Czas=Time)
pon., 19 kwi 2021 o 10:37 Alessio Fabiani <alessio.fabiani at geo-solutions.it>
napisał(a):
> Hi Adrian,
> any chance to provide a data sample?
> You might also check the GeoServer configuration for that layer. See if an
> end-date attribute has been configured or not.
> Alessio.
> Il giorno lun 19 apr 2021 alle ore 10:34 Adrian Bajer <bajeradr at gmail.com>
> ha scritto:
>> Hello,
>> I have a problem with temporal layers (time series) in GeoNode 3.0. My
>> data has two time attributes (Data1 and Data2), but GeoNode doesn't see it
>> as a period of time. Moreover, after layer uploading both attributes gets
>> the same value (you can see on the printscreens below).
>> I want my data to be considered as valid in a period of time, not as
>> points in time.
>> Any ideas how to solve that problem?
>> *Adrian Bajer, MA*
>> *Department of Historical Atlas*
>> Institute of History, Polish Academy of Sciences
>> Rynek Starego Miasta 29/31
>> 00-272 Warsaw, Poland
>> e-mail: bajeradr at gmail.com
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210419/baa8ffd8/attachment-0001.html>
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210419/baa8ffd8/attachment-0001.bin>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210419/baa8ffd8/attachment-0001.png>
More information about the geonode-users mailing list
