[GeoNode-users] Error Installing Geonode: ./docker-build.sh
Édson Flávio de Souza edson.flavio at gmail.com
Tue Aug 10 19:28:42 PDT 2021
Use ls -la for you check permissions on Linux System
The file must to have permissions like this
rwx r_x r_x
Or try execute this command
chmod 755 docker-build.sh
But your message is that the SO not locate the command.
Send us o result the command ls -la in this directory, please.
Other think. Check If you don't have a space between the point and slash
./docker-build.sh is correct
./ or . /docker-build is wrong.
Ok
Edson Flavio
41-98872-5118
@ef_souza - Twitter e Instagram
Em ter, 10 de ago de 2021 19:42, Marcelo Villarroel <
raul.marcelo.villarroel.villazon at gmail.com> escreveu:
> Hi Edson:
> Thanks for your answer. The command is within the directory. How can I
> check if it has permission for execution?
> Best regards,
> On Tue, Aug 10, 2021 at 5:20 PM Édson Flávio de Souza <
> edson.flavio at gmail.com> wrote:
>> Helo,
>> Check if command is in the directory or if it have permission for
>> execution.
>> Em seg., 9 de ago. de 2021 às 21:55, Marcelo Villarroel <
>>> Hi list:
>>> I'm in a clean install of  geonode on Ubuntu Server 18.04.5 LTS:
>>> Memory, 7.7 GB
>>> Processor, Intel® Core™ i7-4790 CPU @ 3.60GHz × 8
>>> Graphics, Intel® HD Graphics 4600 (HSW GT2)
>>> GNOME, 3.28.2
>>> OS type, 64-bit
>>> Disk, 212 GB
>>> I'm following GeoNode Basic Installation steps from:
>>> https://docs.geonode.org/en/master/install/basic/index.html#overview
>>> First Step: Deploy GeoNode on a local server:
>>> My project is named *my_geonode*
>>> Everything went well until Startup the containers:
>>> cd my_geonode
>>> ./docker-build.sh
>>> Inside *my_geonode* folder, running the command
>>> ./docker-build.sh
>>> Get the error message:
>>> *bash: ./docker-build.sh: No such file or directory*
>>> Can you please help me with this error?
>>> Thank you.
>>> Best regards,
>>> *R. Marcelo Villarroel V.*
>>> Ing. Civil, MSc.
>>> *Sistemas de Información Geográfica*
>>> Cochabamba, Bolivia.
>>> Cel.:     (+591) 722 12346
>>> Mail:     raul.marcelo.villarroel.villazon at gmail.com
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> System Analist
>> 41-8872-5118
> Ing. Civil, MSc.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210810/beda88d2/attachment.html>
More information about the geonode-users mailing list
