[GeoNode-users] Error Installing Geonode: ./docker-build.sh
    Marcelo Villarroel
    raul.marcelo.villarroel.villazon at gmail.com
    Wed Aug 11 17:27:47 PDT 2021
Hi Edson:
Many thanks for your reply.
I'm attaching a screenshot.
*my_geonode* folder is already 755. Folders inside are 775. I just finished
learning about the meaning of rwx and numbers associated, Thank you!
Command ./docker-build.sh has no spaces in between.
Running command produces the same message:
*bash: ./docker-build.sh: No such file or directory*
Best regards,
On Tue, Aug 10, 2021 at 10:28 PM Édson Flávio de Souza <
edson.flavio at gmail.com> wrote:
> Use ls -la for you check permissions on Linux System
> The file must to have permissions like this
> rwx r_x r_x
> Or try execute this command
> chmod 755 docker-build.sh
> But your message is that the SO not locate the command.
> Send us o result the command ls -la in this directory, please.
> Other think. Check If you don't have a space between the point and slash
> ./docker-build.sh is correct
> ./ or . /docker-build is wrong.
> Ok
> Edson Flavio
> 41-98872-5118
> @ef_souza - Twitter e Instagram
> Em ter, 10 de ago de 2021 19:42, Marcelo Villarroel <
> raul.marcelo.villarroel.villazon at gmail.com> escreveu:
>> Hi Edson:
>> Thanks for your answer. The command is within the directory. How can I
>> check if it has permission for execution?
>> Best regards,
>> On Tue, Aug 10, 2021 at 5:20 PM Édson Flávio de Souza <
>>> Helo,
>>> Check if command is in the directory or if it have permission for
>>> execution.
>>> Em seg., 9 de ago. de 2021 às 21:55, Marcelo Villarroel <
>>>> Hi list:
>>>> I'm in a clean install of  geonode on Ubuntu Server 18.04.5 LTS:
>>>> Memory, 7.7 GB
>>>> Processor, Intel® Core™ i7-4790 CPU @ 3.60GHz × 8
>>>> Graphics, Intel® HD Graphics 4600 (HSW GT2)
>>>> GNOME, 3.28.2
>>>> OS type, 64-bit
>>>> Disk, 212 GB
>>>> I'm following GeoNode Basic Installation steps from:
>>>> https://docs.geonode.org/en/master/install/basic/index.html#overview
>>>> First Step: Deploy GeoNode on a local server:
>>>> My project is named *my_geonode*
>>>> Everything went well until Startup the containers:
>>>> cd my_geonode
>>>> ./docker-build.sh
>>>> Inside *my_geonode* folder, running the command
>>>> ./docker-build.sh
>>>> Get the error message:
>>>> Can you please help me with this error?
>>>> Thank you.
>>>> Best regards,
>>>> *R. Marcelo Villarroel V.*
>>>> Ing. Civil, MSc.
>>>> *Sistemas de Información Geográfica*
>>>> Cochabamba, Bolivia.
>>>> Cel.:     (+591) 722 12346
>>>> Mail:     raul.marcelo.villarroel.villazon at gmail.com
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> System Analist
>>> 41-8872-5118
>> Ing. Civil, MSc.
Ing. Civil, MSc.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210811/8137d1e9/attachment-0001.html>
Name: Screenshot from 2021-08-11 19-56-27.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210811/8137d1e9/attachment-0001.png>
More information about the geonode-users
