[GeoNode-users] Error Installing Geonode: ./docker-build.sh
    Édson Flávio de Souza
    edson.flavio at gmail.com
    Thu Aug 12 05:50:29 PDT 2021
Checking your folder, the file realy not here.
Try locate this file in other folder, with bin, by example or recheck your
installation.
Att
Em qua., 11 de ago. de 2021 às 21:27, Marcelo Villarroel <
raul.marcelo.villarroel.villazon at gmail.com> escreveu:
> Hi Edson:
> Many thanks for your reply.
> I'm attaching a screenshot.
> *my_geonode* folder is already 755. Folders inside are 775. I just
> finished learning about the meaning of rwx and numbers associated, Thank
> you!
> Command ./docker-build.sh has no spaces in between.
> Running command produces the same message:
> *bash: ./docker-build.sh: No such file or directory*
> Best regards,
> On Tue, Aug 10, 2021 at 10:28 PM Édson Flávio de Souza <
> edson.flavio at gmail.com> wrote:
>> Use ls -la for you check permissions on Linux System
>> The file must to have permissions like this
>> rwx r_x r_x
>> Or try execute this command
>> chmod 755 docker-build.sh
>> But your message is that the SO not locate the command.
>> Send us o result the command ls -la in this directory, please.
>> Other think. Check If you don't have a space between the point and slash
>> ./docker-build.sh is correct
>> ./ or . /docker-build is wrong.
>> Ok
>> Edson Flavio
>> 41-98872-5118
>> @ef_souza - Twitter e Instagram
>> Em ter, 10 de ago de 2021 19:42, Marcelo Villarroel <
>>> Hi Edson:
>>> Thanks for your answer. The command is within the directory. How can I
>>> check if it has permission for execution?
>>> Best regards,
>>> On Tue, Aug 10, 2021 at 5:20 PM Édson Flávio de Souza <
>>>> Helo,
>>>> Check if command is in the directory or if it have permission for
>>>> execution.
>>>> Em seg., 9 de ago. de 2021 às 21:55, Marcelo Villarroel <
>>>>> Hi list:
>>>>> I'm in a clean install of  geonode on Ubuntu Server 18.04.5 LTS:
>>>>> Memory, 7.7 GB
>>>>> Processor, Intel® Core™ i7-4790 CPU @ 3.60GHz × 8
>>>>> Graphics, Intel® HD Graphics 4600 (HSW GT2)
>>>>> GNOME, 3.28.2
>>>>> OS type, 64-bit
>>>>> Disk, 212 GB
>>>>> I'm following GeoNode Basic Installation steps from:
>>>>> https://docs.geonode.org/en/master/install/basic/index.html#overview
>>>>> First Step: Deploy GeoNode on a local server:
>>>>> My project is named *my_geonode*
>>>>> Everything went well until Startup the containers:
>>>>> cd my_geonode
>>>>> ./docker-build.sh
>>>>> Inside *my_geonode* folder, running the command
>>>>> ./docker-build.sh
>>>>> Get the error message:
>>>>> Can you please help me with this error?
>>>>> Thank you.
>>>>> Best regards,
>>>>> *R. Marcelo Villarroel V.*
>>>>> Ing. Civil, MSc.
>>>>> *Sistemas de Información Geográfica*
>>>>> Cochabamba, Bolivia.
>>>>> Cel.:     (+591) 722 12346
>>>>> Mail:     raul.marcelo.villarroel.villazon at gmail.com
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> System Analist
>>>> 41-8872-5118
>>> Ing. Civil, MSc.
> Ing. Civil, MSc.
System Analist
41-8872-5118
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210812/ad7c62c1/attachment.html>
More information about the geonode-users
