[GeoNode-users] Error Installing Geonode: ./docker-build.sh
Marcelo Villarroel
raul.marcelo.villarroel.villazon at gmail.com
Fri Aug 13 19:11:04 PDT 2021
The file (docker-build.sh) was located at /*geonode-project* folder, not at
/*my_geonode *folder as indicated in GeoNode Basic Installation steps.
Thanks for the suggestion.
On Thu, Aug 12, 2021 at 8:50 AM Édson Flávio de Souza <
edson.flavio at gmail.com> wrote:
> Checking your folder, the file realy not here.
> Try locate this file in other folder, with bin, by example or recheck your
> installation.
> Att
> Em qua., 11 de ago. de 2021 às 21:27, Marcelo Villarroel <
> raul.marcelo.villarroel.villazon at gmail.com> escreveu:
>> Hi Edson:
>> Many thanks for your reply.
>> I'm attaching a screenshot.
>> *my_geonode* folder is already 755. Folders inside are 775. I just
>> finished learning about the meaning of rwx and numbers associated, Thank
>> you!
>> Command ./docker-build.sh has no spaces in between.
>> Running command produces the same message:
>> *bash: ./docker-build.sh: No such file or directory*
>> Best regards,
>> On Tue, Aug 10, 2021 at 10:28 PM Édson Flávio de Souza <
>>> Use ls -la for you check permissions on Linux System
>>> The file must to have permissions like this
>>> rwx r_x r_x
>>> Or try execute this command
>>> chmod 755 docker-build.sh
>>> But your message is that the SO not locate the command.
>>> Send us o result the command ls -la in this directory, please.
>>> Other think. Check If you don't have a space between the point and slash
>>> ./docker-build.sh is correct
>>> ./ or . /docker-build is wrong.
>>> Ok
>>> Edson Flavio
>>> 41-98872-5118
>>> @ef_souza - Twitter e Instagram
>>> Em ter, 10 de ago de 2021 19:42, Marcelo Villarroel <
>>>> Hi Edson:
>>>> Thanks for your answer. The command is within the directory. How can I
>>>> check if it has permission for execution?
>>>> Best regards,
>>>> On Tue, Aug 10, 2021 at 5:20 PM Édson Flávio de Souza <
>>>>> Helo,
>>>>> Check if command is in the directory or if it have permission for
>>>>> execution.
>>>>> Em seg., 9 de ago. de 2021 às 21:55, Marcelo Villarroel <
>>>>>> Hi list:
>>>>>> I'm in a clean install of geonode on Ubuntu Server 18.04.5 LTS:
>>>>>> Memory, 7.7 GB
>>>>>> Processor, Intel® Core™ i7-4790 CPU @ 3.60GHz × 8
>>>>>> Graphics, Intel® HD Graphics 4600 (HSW GT2)
>>>>>> GNOME, 3.28.2
>>>>>> OS type, 64-bit
>>>>>> Disk, 212 GB
>>>>>> I'm following GeoNode Basic Installation steps from:
>>>>>> https://docs.geonode.org/en/master/install/basic/index.html#overview
>>>>>> First Step: Deploy GeoNode on a local server:
>>>>>> My project is named *my_geonode*
>>>>>> Everything went well until Startup the containers:
>>>>>> cd my_geonode
>>>>>> ./docker-build.sh
>>>>>> Inside *my_geonode* folder, running the command
>>>>>> ./docker-build.sh
>>>>>> Get the error message:
>>>>>> Can you please help me with this error?
>>>>>> Thank you.
>>>>>> Best regards,
>>>>>> *R. Marcelo Villarroel V.*
>>>>>> Ing. Civil, MSc.
>>>>>> *Sistemas de Información Geográfica*
>>>>>> Cochabamba, Bolivia.
>>>>>> Cel.: (+591) 722 12346
>>>>>> Mail: raul.marcelo.villarroel.villazon at gmail.com
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> System Analist
>>>>> 41-8872-5118
>>>> Ing. Civil, MSc.
>> Ing. Civil, MSc.
> System Analist
> 41-8872-5118
Ing. Civil, MSc.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210813/315439ff/attachment.html>
More information about the geonode-users
