[GeoNode-users] Unexpected error! - error Error Code. Contact the system administrator ...
Israel López asralf at gmail.com
Fri Jan 8 13:26:58 PST 2021
Hi dear devs
Same problem on my local machine running with spc geonode scripts the 3.x
branch.
Any fix?
Thanks.
El mar, 22 de dic. de 2020 a la(s) 11:08, Ariel Cabezas (
gerardoarielc at gmail.com) escribió:
> Hi again, good morning / afternoon
> Another question, the navigation in the Geonode portal is working fine.
> I'm logged in with Admin., I can upload documents of the PDF type
> perfectly. But I can't upload shape data layers, I use shape format (shp,
> dbf, shx, prj), CRS 4326, the data layers have very few elements ,. It
> shows me the progress of the data load, then the message "performing the
> Geoserver configuration" and then the message: "Unexpected error! - error
> Error Code. Contact the system administrator for more information regarding
> this error message."
> And it doesn't show me any loaded data layer. But from the "UPLOADS"
> Administration menu I can see the attempts to upload files in the "PENDING"
> state.
> Thanks for any help please!
> Ariel
> PD:
> I did the Geonode installation with the instructions on the website
> https://docs.geonode.org/en/master/install/basic/index.html
> I was assigned a virtual machine with enablement of ports 8062 for web and
> the SSH port. Ubuntu Server 18. The IP is in this format Public-IP: 8062. I
> did the installation remotely through SSH.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210108/e9500b0d/attachment.html>
More information about the geonode-users mailing list
