[GeoNode-users] Unexpected error! - error Error Code. Contact the system administrator ...
Ariel Cabezas
gerardoarielc at gmail.com
Tue Jan 12 20:22:41 PST 2021
Hi Israel, geonode developers,
did you have any solutions or news ?
I can upload kml files, but everything is represented by points regardless
of whether it is a layer of lines or polygons.
Best regards,
El vie, 8 ene 2021 a las 18:27, Israel López (<asralf at gmail.com>) escribió:
> Hi dear devs
> Same problem on my local machine running with spc geonode scripts the 3.x
> branch.
> Any fix?
> Thanks.
> El mar, 22 de dic. de 2020 a la(s) 11:08, Ariel Cabezas (
> gerardoarielc at gmail.com) escribió:
>> Hi again, good morning / afternoon
>> Another question, the navigation in the Geonode portal is working fine.
>> I'm logged in with Admin., I can upload documents of the PDF type
>> perfectly. But I can't upload shape data layers, I use shape format (shp,
>> dbf, shx, prj), CRS 4326, the data layers have very few elements ,. It
>> shows me the progress of the data load, then the message "performing the
>> Geoserver configuration" and then the message: "Unexpected error! - error
>> Error Code. Contact the system administrator for more information regarding
>> this error message."
>> And it doesn't show me any loaded data layer. But from the "UPLOADS"
>> Administration menu I can see the attempts to upload files in the "PENDING"
>> state.
>> Thanks for any help please!
>> Ariel
>> PD:
>> I did the Geonode installation with the instructions on the website
>> https://docs.geonode.org/en/master/install/basic/index.html
>> I was assigned a virtual machine with enablement of ports 8062 for web
>> and the SSH port. Ubuntu Server 18. The IP is in this format Public-IP:
>> 8062. I did the installation remotely through SSH.
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210113/866b6dba/attachment.html>
More information about the geonode-users
