[GeoNode-users] Raster series as temporal layer
Alexander Petkov
greenkov at gmail.com
Thu Jan 21 05:38:54 PST 2021
I mean that in the metadata is visible start date/end date for the layer.
On Thu, Jan 21, 2021 at 6:35 AM Simone Giannecchini <
simone.giannecchini at geo-solutions.it> wrote:
> Hi Alexander,
> what do you mean by " Now I am wondering if it is possible to expose the
> temporal extent as well, in the metadata viewable in Geonode "?
> Regards,
> Simone Giannecchini
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services for more information.
> Ing. Simone Giannecchini
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 333 8128928
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> On Thu, Jan 21, 2021 at 10:12 AM Alexander Petkov <greenkov at gmail.com>
> wrote:
>> Hello Simone and Geonode users:
>> I have configured the Mosaic in Geoserver with Time dimension enabled,
>> and ran the updatelayers command.
>> The layer is recognised and listed in Geonode.
>> Now I am wondering if it is possible to expose the temporal extent as
>> well, in the metadata viewable in Geonode.
>> Thank you in advance with any pointers,
>> Alex
>> On Wed, Jan 20, 2021 at 11:28 AM Simone Giannecchini <
>>> Hi Alexander,
>>> I think this is more of a GeoServer related question.
>>> If you can set up an ImageMosaic in GeoServer then you can use the
>>> updateLayers management command and have this layer become a GeoNode layer.
>>> Obviously the work is a little more complicated than that, I was just
>>> trying to give you some directions.
>>> There are quite a number of documents around for setting up a raster
>>> time series in GeoServer...
>>> Regards,
>>> Simone Giannecchini
>>> @simogeo
>>> Founder/Director
>>> GeoSolutions S.A.S.
>>> Italy
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> On Wed, Jan 20, 2021 at 1:56 PM alexander-petkov <greenkov at gmail.com>
>>> wrote:
>>>> I have the same question--Is it possible to expose the Time dimension
>>>> for a
>>>> raster layer in Geonode?
>>>> The layer is updated daily, so the time dimension changes.
>>>> Kind regards,
>>>> Alex
>>>> Sent from:
>>>> http://osgeo-org.1560.x6.nabble.com/GeoNode-users-f5185389.html
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210121/9ee17a88/attachment.html>
More information about the geonode-users
