[GeoNode-users] Raster series as temporal layer
Alexander Petkov greenkov at gmail.com
Thu Jan 21 05:51:43 PST 2021
I think this is what I am looking for:
https://docs.geonode.org/en/stable/usage/managing_maps/exploring_maps/timeline.html
On Thu, Jan 21, 2021 at 6:38 AM Alexander Petkov <greenkov at gmail.com> wrote:
> I mean that in the metadata is visible start date/end date for the layer.
> On Thu, Jan 21, 2021 at 6:35 AM Simone Giannecchini <
> simone.giannecchini at geo-solutions.it> wrote:
>> Hi Alexander,
>> what do you mean by " Now I am wondering if it is possible to expose the
>> temporal extent  as well, in the metadata viewable in Geonode "?
>> Regards,
>> Simone Giannecchini
>> GeoServer Professional Services from the experts!
>> Visit http://bit.ly/gs-services for more information.
>> Ing. Simone Giannecchini
>> @simogeo
>> Founder/Director
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39  333 8128928
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
>> On Thu, Jan 21, 2021 at 10:12 AM Alexander Petkov <greenkov at gmail.com>
>> wrote:
>>> Hello Simone and Geonode users:
>>> I have configured the Mosaic in Geoserver with Time dimension enabled,
>>> and ran the updatelayers command.
>>> The layer is recognised and listed in Geonode.
>>> Now I am wondering if it is possible to expose the temporal extent  as
>>> well, in the metadata viewable in Geonode.
>>> Thank you in advance with any pointers,
>>> Alex
>>> On Wed, Jan 20, 2021 at 11:28 AM Simone Giannecchini <
>>>> Hi Alexander,
>>>> I think this is more of a GeoServer related question.
>>>> If you can set up an ImageMosaic in GeoServer then you can use the
>>>> updateLayers management command and have this layer become a GeoNode layer.
>>>> Obviously the work is a little more complicated than that, I was just
>>>> trying to give you some directions.
>>>> There are quite a number of documents around for setting up a raster
>>>> time series in GeoServer...
>>>> Regards,
>>>> Simone Giannecchini
>>>> @simogeo
>>>> Founder/Director
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> On Wed, Jan 20, 2021 at 1:56 PM alexander-petkov <greenkov at gmail.com>
>>>> wrote:
>>>>> I have the same question--Is it possible to expose the Time dimension
>>>>> for a
>>>>> raster layer in Geonode?
>>>>> The layer is updated daily, so the time dimension changes.
>>>>> Kind regards,
>>>>> Alex
>>>>> Sent from:
>>>>> http://osgeo-org.1560.x6.nabble.com/GeoNode-users-f5185389.html
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210121/deb572e7/attachment.html>
More information about the geonode-users mailing list
